Results 16 to 30 of 346
Threaded View
    Nov 2011
    South Belfast, Norn Iron
    Default AutoBouquets E2 28.2E plug-in
    Originally posted on on SGTFlipFlops SKYUK Bouquet thread.
    I still feeeling my way around this plug-in, but it seems great so far .......
    I can highly recommend AutoBouquets E2 28.2E
    Updates your E2 box with Sly numbered bouquet set specifically for YOUR region. You set your region in the menu.
    I've mine set to "Northern Ireland HD", so I get the BBC and ITV channels downloaded for NI and it means I also get the ROI channels on 161, 162 & 163. No editing required.
    It can be tailored to only download specific bouquets and can be scheduled to run overnight.
    Fantastic plug-in if you want regional Sly numbered setup without the need to modify existing bouquets.
    It bascially fully automates the Sly numbering and automatically keeps it up to date. I'll be using SGTFlipFlop's non-Sly bouquets to compliment the auto bouquets though.
    Options for AutoBouquets E2 28.2E
    Use HD First Bouquet
    Puts the HD channels starting at position 6 immediately after 1-5 (BBC1, BBC2, ITV1, C4, C5 for your region).
    Show Channel Numbers
    Puts the channel number in front of the channel name. ?104 ? Channel 4?, instead of ?Channel 4?.
    Use Internal NIT Scan
    Doesn?t seem to make any difference? Finds new/modified transponders. It doesn't seem to make any difference because the transponders rarely change. The only changes in the last few months are the BBC HD transponder changing to 8PSK, C4 HD transponder changing back to DVB-S, the Olympic transponders closing, and a couple of switches to HD.
    Use Pli Placeholders
    Only works on images using an OpenPLi base. It skips the placeholders. If set to YES, it doesn?t keep the Sly numbering on my DM800HD SE running Dream Elite 3. Works on VIX on my Duo.
    Create Child Friendly
    Guessing it parental locks some bouquets
    Make Default Bouquets
    Custom Channel Order
    Allows you to re-order the Sly channels?
    Scheduled Update Scan
    Runs the plug-in at the specified time
    Attached the 20160609 version, along with my own Custom Swap file.
    Last edited by DMBoot; 7th August, 2016 at 11:01 AM. Reason: Adding June 2016 version
  2. The Following 14 Users Say Thank You to DMBoot For This Useful Post:
    AndyT83 (24th November, 2013), Diddly (19th December, 2013), DPDD (3rd September, 2016), gadgetgarry (3rd June, 2015), Greengo (17th September, 2014), matecuk1 (25th January, 2014), ozzy30 (29th March, 2014), rallymad (19th May, 2014), silverfox (15th April, 2017), slimefc (30th January, 2014), temmy (12th October, 2013), WOODWARD395 (3rd November, 2013)
