I have installed this plug in and it seems to be working fine, although it takes around 30 minutes to complete on my D800. The only problem I have found is the BBC Interactive bouquet which reports 'tuner failed' on each of the channels. These channels have worked previously on my manual updates of SGT Flip Flops channels. Do these channels work for everyone else?
The BBC has shut down most of it's RED Button streams on dsat
http://www.bbc.co.uk/blogs/abouttheb...ing-BBC-One-HD
Sent from my HTC using Tapatalk 2
The only Interactive channel left is on 10773 H 22000 5/6, you may have to do a fresh scan to update lameDB or Lraz may have to modify the script for the change.
OR you can modify the script yourself!
change epg to 2051 on line 447:
and also change epg range to 2050-2053 on line 667:Code:"2051") bouquetname "12" "BBC Interactive"
run plugin to create latest BBCi bouquetCode:if [ $epg -gt 2050 -a $epg -lt 2053 ]; then ca="FTA"; sn="BBCi $epg"
hi all, installed autobouquets e2, on my dm800 hd pvr box. when i try and start it tells me to press menu to setup, but after pressing menu the box just crashes and reloads, any suggestions, thx mac
hi, how much memory do you have available on your box.
everytime i went into a menu and tried to come out again my box would crash with a green screen message saying not enough space so i reflashed it and now i have 13mb free space out of the 60mb total space available and it's all working ok now
DM800HD PVR clone
90cm dish - motorised
dbj159 (26th May, 2013)
I cant get it to work, it says cannot connect to remote host.
Im using OpenPLI on Vu+ duo, any ideas?
f1 interactive are unamed but there as 6390..1
tried my nut off today to get this working yet i cant get any options for the plug in , and then my box crashes , any clues guys?
cheers for this it works really well on my vu solo can you tell me is there an enigma 1 one that will also auto update thank-you
