Page 9 of 24 FirstFirst ... 456789101112131419 ... LastLast
Results 121 to 135 of 346
  1. #121
    May 2012
    I'm running the autobouquets from the lates Vix release version.
    My region is set to London HD but when the box scans it misses out the Setanta sports channels. I'm sure it misses others but these are the ones that I want.
    Is there any way to put these channels in and keep them there permanently?
  2. #122
    May 2008
    This version of AutoBouquets E2 is for MIPSEL boxes only!
    sources are included for you to compile for other boxes.
    21-02-2013
    AutoBouquets E2 code has been 90% rewritten and optimized
    for speed. main coding has now been moved into binaries.
    script checking can be disabled for none comaptible boxes.
    run AutoBouquets Downloader in background via blue button.
    custom.txt channel swap file has be slightly simplified.
    now just enter channels to swap with each other. 105=171
    if you are manually copying the usr folder to your box? insead
    of using the .ipk installer then you must chmod 755 these files:
    autobouquets_e2.sh, autobouquets, autolamedb
    .ipk installer should still auto install dvbsnoop for you as
    long as dvbsnoop is available in the feeds on your box. if not,
    you will still need to pre install dvbsnoop prior to installing
    this new .ipk installer. have fun testing this this latest beta!
  3. The Following User Says Thank You to LraiZer For This Useful Post:
  4. #123
    Oct 2010
    Hi I have a DM500HD which has a 400mhz mips processor is this box a mipsel box or not so that I can use this version?
    Mark
  5. #124
    Jan 2009
    will this work on tm800hd box thanks
  6. #125
    Thanks LraiZer for the update.
    Pls which box/boxes are refered to as 'MIPSEL' boxes?
    Will DM800HD qualify as one?
    Quote Originally Posted by LraiZer View Post
  7. #126
    The plugin has stopped working on my Vu+ Duo.
    I want to update the bouquet but when i press green to start, it goes to the black screen with white writing as before but after 1 second it goes back to plugin screen.
    its difficult to see what it says on the black screen as it goes so quick but i think it says something like "cant connect to host".
    Any ideas?
  8. #127
    May 2012
    Thanks for this, have been using an earlier version on my Vu Duo but will give this latest update a try
  9. #128
    DK Veteran lincsat's Avatar
    Jun 2008
    Quote Originally Posted by iceman325 View Post
    Any ideas?
    Did you CHMOD the binaries?
    You should also be OK to fully remove it, reboot, then install the new version and reboot.
  10. #129
    Jan 2013
    @ iceman325
    try turning off the Enable Script Checks option in AutoBouquets menu to bypass the error checking communication between plugin and connection to host.
  11. #130
    Jan 2009
    Hi, thanks for posting this great plugin.
    Just 2 questions:
    1) What is a MIPSEL box. I have DM800HD original and DM800SE sim2.1
    2) How can i get the placeholders removed so that BBC1 is number 1, BBC2 is number 2... etc, not 101 and 102.
  12. #131
    Old Git PaphosAL's Avatar
    Mar 2008
    Quote Originally Posted by tlj999 View Post
    Just 2 questions:
    Sorry, no idea on question 1, as I can't afford such luxuries...
    But you might find the answer to question 2 by reading the original notes in post #1 of this thread, where it states that an OpenPLi-based image is required in order to start channel numbering from 1 and up, not 101 and up (which would do my head in too, and Wifey's- thank God for Commando 14.7 and DM500S, LOL!)
    Cheers- AL
  13. #132
    Jan 2013
    Just 2 questions:
    1) Both these boxes are MIPS boxes so should work in theory with this plugin.
    2) First turn off the Use HD First Bouquet option in the autobouqets menu. Then also turn off the Make Defaults Bouquets option. Run the plugin, then delete the UK Bouquets list using the remote. All placeholders should now be totaly removed and your channels will start at number 1.
  14. #133
    Mar 2008
    Crikey deadbeef, you seem to know more about LraiZer's plugin than the great man himself!
    Cheers- AL
  15. #134
    Jul 2011
    I have a 800HD box and installed manually, works fine!
  16. #135
    May 2008
    fixed missing channels bug. added bouquet style options.
    added supplement.txt file for manual service additions.
    when using the supplement.txt file to manually add channels,
    its best to add your channel with a channel number that puts
    the new channel into an empty slot in the "other" bouquet.
    current empty slots are 975 < 995. you can then simply add a
    switch entry in the custom.txt file to swap with another one.
  17. The Following 6 Users Say Thank You to LraiZer For This Useful Post:
    CableFella (29th July, 2013), colinh1213 (24th June, 2013), jazzist (29th June, 2013), Liverpool1981 (26th July, 2013), monkified (10th July, 2013), Sat-Shop (30th March, 2013)
