Results 1 to 14 of 14
    Europa
    Default opel astra 2.0 dti and vp44 I need help
    hi
    I have opel astra 2.0 dti year 2000 with pumpe vp44.
    I have problems with pumpe VP44.
    I have the electronic pumpe totally destroyed.
    I have installed a second-hand one, but the car will not start.
    now I have dtc: pumpe blocked by immo.
    I can I reset this pumpe?
    or the ecu?
    any help?
    Serbia
    Use search button...
    Here is manual how to program pump you need opcom
    Zippyshare.com - Opcom Diesel Pump Programming.pdf
    Europa
    hi
    this is for psg16.
    I have vp44/psg5
    any help?
    Senior Member kardi78's Avatar
    Sep 2012
    Hungary
    Bosch number same like destroyed?
    Serbia
    Hi! Are you good read manual?
    "Astra-G and Zafira-A can also be installed with a VP44/PSG5 for Y20DTH. These PSG5 units
    don't need to be reset."
    To install this PSG5 pump you don t need code from donor pump. It must work when you put in car
    So maybe donor pumpe is not good also..
    Jul 2012
    Is your diesel pump the single plug type? If it is the replacement diesel pump will plug in and work, no programming needed
    Quote Originally Posted by radb02 View Post
    Yes VP44/PSG5 is single pug.
    B.r.
    May 2019
    Italy
    Restoring this thread for a problem I'm having with the same pump Bosch VP44 PSG5 mounted on an Astra G.
    I just replaced the PSG5 module without removing pump from engine cause the broken one gave me a P1630 error.
    Now I got the yellow spanner light, the engine doesn't start and the pump makes a noise like a "trrrrr" after I try to start.
    What it can be?
    I tried to read errors with a very cheap OBD2 bluethoot scanner that gave me 0 errors
    check power 12v if ok ecu psg5 is brocken
  10. The Following User Says Thank You to slawarek For This Useful Post:
    abgx (24th May, 2019)
  11. #10
    May 2019
    Italy
    Where should I check the 12Volts? On pump or from the cable?
    Also I've read that the P1630 might be the solenoid located at the centre of the pump.
    I changed only the PSG module but solenoid is the old one.
  12. #11
    May 2019
    Italy
    UPDATE:
    Checking voltage on pins 7 and 6 I've 12 volts. The donor pump was working fine. I've replaced also the solenoid but still the engine doesn't start. From injectors pipes I've a low pressure, I can close fuel with a finger
  13. #12
    if 12volt its ok check transistor in driver psg5
  14. #13
    May 2019
    Italy
    Hallo guys,
    after a lot of attempts I decided to give up and buy a new ECU for my VP44.
    The question is, what I need to do if I buy a new or used ECU PSG5 for 015 Bosch pump? Does it work by just fitting it on the pump?
    My car is an ASTRA G engine code Y20DTH
  15. #14
    Jul 2013
    yorkshire
    You are dicing with death my friend. Your diagnosis is dangerous. You put your finger over fuel delivery!!!!!!!!!This post should be deleted before some other idiot try,s this.
