I have rev72 clone 800hd and struggle to get epg on it with the following image "NabiloBlackHole_DM800_012_BL72.nfi"
I would prefer a pli jade image like I use on dm500 if possible
otherwise a commando image.
Can anyone point to correct one for above box please
I put ssl84 on it and it promptly bricked because I assume mine is and old one.
putting the above flash on repaired it but I don't like the image
It's too cumbersome.
I like the commando 14.5 image and pli jade for dm500's hence request.
Thanks for suggestion
Openpli is ok but a bit basic imho but ive stuck with Dreamelite blackhole phoenix edition very similar to the old blackhole image.
Its in downloads.
Andy.
please press the little red THANKS tab
if I helped if not press the green tab to tell me to f**Koff
if you have sim 2.01 in it then flash the Dream Elite 3.0 DM800HD-ramiMAHER #ssl84b
This image is good and fast.. you will need to manualy install "TSpanel" and then download the Extra Url from the addons in tspanel its under the blackhole addons i think i got mine from the very first section of addons..
once installed with the extra url press the blue button and then go to extra url install your cccam you need and shot your settings over via db-edit.
excellent image just a bit annoying trying to get a cam installed :S
[quote=spudorange;1604398]fair point BUT AS MENTIONED I don't have sim 2.01
Originally Posted by 50pounds
you can pick a sim 2.01/2.10 sim card up pretty cheap, about ?20 i think so maybe its time for a upgrade then.. regards mdt
I have DM800HD PVR i need gemini 3.2.2 but when i download it from dreambox site it hngs during the loading. is there anyone who can advice which imahe should i download..
Hi i am New to the scene,just got a dm800hd clone,whats the best image to use thats easy to setup the hard drive,when i try to initialise,it says hard drive not found even though it shows it on the display and even tells the size???? many thanks in advance
have you mounted it, also??
It was mentioned earlier in the thread but I think the Open Pli images are the best , I've got it on Dm800se and Dm800hd (different images),
everything just works as it should no messing about with 1channel, trying to mount USB or problems with CrossEpg
