Results 1 to 4 of 4
    Nov 2008
    Default Tuner issue in Clone Duo
    Hi All,
    Not exactly sure what the problem is. I have a new Duo which is connected only on tuner A as the other cable is broken and havent gotten round to fix it. It was working fine for 1 day then afterwards, its showing tune failed... rebooted the box to no avail. could there be a problem with the tuner or I should connect both tuner to get to the bottom of the problem?
    could the issue be motherboard related as well.
    Thanks in advance.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Could be the other cable is broken too.You better check your dish works first or try your box at someone elses then you can take it from there.
    Nov 2008
    Quote Originally Posted by DOUGALMCD View Post
    Actually I have tested the box elsewhere and it works fine didnt get the tune failed message at all. The Cable actually works fine prior to connecting the VU box, it was previously connected to a Sly box so I can reasonably say the cable is fine.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    If your box worked perfectly elsewhere. I would check lnb and your cable and connections thoroughly. The tuners may be sensitive and your set up may be out slightly.
