Results 1 to 7 of 7
    Jan 2009
    Default Help frequencies 500C
    Hi, I?am living in Madeira and can not manage the frequencies to record the search, only the free channels so far. I already chance the frequencies on the "cablexml" to the ones here although no joy so far. I leave the frequencies here expecting someone understands this better than me.....
    I use a gemini 4.6 and doing CS with MBOX.
    Em root, vais a /var/etc "<cable name="All (SR6875)" satfeed="true" flags="9">"
    <transponder frequency="185000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="443200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="451200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="459200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="467200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="475200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="483200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="491200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="499200" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="546000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="611000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    <transponder frequency="619000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
    "All (SR6875)"
    WHATS WRONG HERE???
    Administrator
    Devilfish's Avatar
    Feb 2008
    The cables.xml holds the scanning frequencies and symbol rate.
    When you do a transponder scan, this is where the receiver looks for the frequencies.
    The SR6875 is for Germany somewhere. You will need to know the default frequency and symbol rate for your cable company.
    Even after to scan in all the channels available, you will only be able to view FTA channels. The emu allows you to view encrypted channels. But only if the encryption method used by the cable company has been hacked. You will need to tell us what encryption they use before we can tell you if it's hacked or not.
    Jan 2009
    Hi Devilfish, I?m in Madeira "Portugal", and the symbol rate is 6875, and they use the Kudelsky encryption 1802 nagra3.
    The Cabo company is Zonmadeira, they operate all over the country although there is different frequencies here in Madeira.
    Thanks in advance
    V.I.P. Member westkill's Avatar
    May 2008
    just an idea
    have you tryed doing a manual scan
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    Jan 2009
    yes, the problem the "PIDs" which I do not have and don't have an idea how to get them.....
    Administrator
    Devilfish's Avatar
    Feb 2008
    If you can get the 'default frequency' you can do a complete scan.
    Nagra3 is not hacked so you won't be able to view premium channels with an emu.
    Jan 2009
    And how can I manage to get hands on that default frequencies, I?m using CS with MBOX, and I had this channels, not all of them, but some encrypted. My mistake was doing a new search without saving those frequencies, now is impossible so far getting those back, with the same frequencies....
