Results 1 to 8 of 8
    alfons37's Avatar
    Default Initial startup problem-- Xentry error
    I have sdconnect (china) (ibm T30 with finish harddrive) mercedes, i try to initial startup and manual guide.
    When i try it give me error...
    What do i need for fix this problem
    alfons37's Avatar
    Default More info
    I think i need offline for this shall work...
    HW-ID 566ADC3DA6C2
    APP-ID 253
    LAN-ID 08000119DFA5
    iF I USE NEW KEY I THINK IT WORK
    alfons37's Avatar
    Default Xentry error
    Now I have changed my license key, but still does not work. Someone must have had the same problem
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by alfons37 View Post
    becose you have das32 standalone... NOT ORIGINAL..
    first to do this .. just open exntry..
    alfons37's Avatar
    Default Xentry
    Thanks for answer
    Can you explane better what du you mean with .. just open exntry..
    alfons37's Avatar
    Default Install from beginning
    Or must i install all from beginning?
    Jun 2009
    no need to install all from the beginning.. just replace your das32r2.. with the orginal for your version..
    and you will START DAS always FROM XENTRY..
    alfons37's Avatar
    Default das32r2
    Need orginal das32r2.exe for 11-2011
    Anyone have this?
