Results 1 to 4 of 4
    Default DFP ? EDC16C34 Peugeot 307
    hello some one can check this file i think is ecu problem on dfp ?
    on my friend give this car and havent power for accelerate very slow and sometime have boost . he have turbo and other parts and car always have problem
    ps car dont have dtc registred after esrase fault and have again after 10 minutes
    it will be grateful
    Jul 2012
    your file is egr on
    the dpf seems to be closed well, but to better understand you have to make a comparison with the original file ..
    it may have been touched something that is causing the problem
    Quote Originally Posted by mario38 View Post
    your file is egr on
    i dont have original file i do anyting in this car just i suspect DFP may be bad removed?
    my frieng have bought this car like that
    Jul 2012
    the dfp is off .. but you do not understand all the changes made ..
    would be good to have the original file and make a comparison.
    or try to write original file and see if the fault disappears
