again needs help ...
Because the firewall is enabled the system broke the connection during the software update.
symptoms:
- It connects with the car but do not work immo advanced features (VCM cant see ingniton).
- The options do not show the serial number and version fw.
- I can't connect to the ftp VCM
- firmware software not update between ids versions even after the change to JLR
I did
Installing older versions and newer ids for Ford / LR. Every time the cable connects to the car without updating fw
ClearVCMUltil - Goes procedure without errors but it does not change anything.
please help
same problemmma...
i have 2 vcm's with corrupted dumps.
with one of them i played a long time,was build interface for Coldfire BDM ,to read and write vcm flashes, based on altera pld for Codewarrior,or soft by PEmicro,, but still no chance,because have no right dumps...may be some one has any idea??
hello. i am looking for a solution to the same problem. my device has stoped working. many thanks for any solution
1.clearvcmutil
2. flash over from JLR t0 Ford and viceversa..
Whatever seems impossible is just not yet important enough.
clearvcmutil and IDS JLR not solve the problem because even after change to JLR software not flash interface ....
You'll need a pda to flash it then..Never needed a pda myself though.
do you know someone with pda ?
Yes. A have Asus A696. I can organize other pda.
Do you know how to connect vcm to pda ?
I think using this:
https://rotunda.spx.com/en-US/Pages/...1&catID=276332
IS anybody knows how to connect usb cable from pda directly to VCM Pcb ?
Board of my vcm look like it is impossible to connect via ext connector .....
PDS installed on my Asus and tried to connect to the ISP1362 (OTG_DP1, OTG_DM1). Always I don/t have communication. As I wrote earlier in my VCM to external connector goes only LAN lines so I think if buy a cable from ebay this also not solve my problem.
Please any help to connect VCM to PDA.
I did exchange bga flashes and vcm back to the live
