br.balazs (5th September, 2016)
please any help???
nobody know how?
removing the dpf from this denso is not hard, in fact its very easy. Software is not the problem
the trouble with these cars in that you need the dealer tool to perform resets after.
also If any of the sensors are failed, egt sensor, pressure sensors then its unlikely the DPF delete will work for long and the light comes back on because of the fault
check this m8
autobamm file same as ori, i compare bin no diferences. can you give a look?
m8... there are 397bytes difference... so please compare it again.
don't share password... a lot of "sharks" need solution for this ECU
i compare with winhex no diference of ori file, mate
friend.. write file I sent to you and stop comparing... you loose your time.
it"s mod !....................
Friend thanks for all, but car only work good one day, now its again without power. can you give another look??. thanks
please can someone give me a help???
Hiya, I have a Navara 2007 that I require the DPF removing from ECU.
I'm a nissan master tec by trade and have not done this type of thing before, I have the deal tools but they are unable to remove the DPF from ECU
My question is how and what equipement do I require to carry out DPF off on the denso ECU
Cheers for any help
you only need a programmer to read it, i use piasini and the right file.
