Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    DK Veteran nibblitz's Avatar
    Do you know why you want to change the firmware?
  2. #17
    daithi's Avatar
    May 2009
    ireland
    strange my box has just started acting the same
    wont show premium channels but fta are fine
    ethernet in back of box is flashing like mad confused
    no settings been changed as herself doesnt no how to access it
  3. #18
    Sep 2011
    I have the OpenBox S10
  4. #19
    May 2012
    Quote Originally Posted by pbul2004 View Post
    Stick this on. Its clone safe and channel list included with favourites named.
    http://www.digital-kaos.co.uk/forums...one-safe-2368/
  5. #20
    Sep 2011
    Right.... to add to the confusion even more, MY BOX WORKS AT MY MATES!!
    Why would my box work at my mates house, but not at my own? Yet his box works at my house??
    Any ideas?
  6. #21
    Sep 2011
    I think its something to do with my box, my box is hardwired into the router via an ethernet cable.
    My router doesnt recognise that the box is connected (there is no green light on the router).
    Soon as i try other boxes, the green light appears straight away and works.
    What could be the possible causes for this? The box?
    Please help anyone, thanks
  7. #22
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Looks like could be a fault with the lan adapter on the box itself.
    Patience is a virtue.
  8. #23
    May 2012
    Before this you said "MY BOX WORKS AT MY MATES" so the only difference is:
    1, Your Internet Connection/Router
    2, Your etnernet cable (Assuming adifferent ethernet at your mates)
    Process of elimination.
    When you have connected the box and it is on a prem channel, try rebooting your router, then you box. Dont have any other devices connected to your router when trying.
  9. #24
    Oct 2012
    Northern Ireland
    Quote Originally Posted by DW190 View Post
    @the op
    Happened to me.
    I removed my WPA and set my router to no password. It helped a lot, with some channels scrambled and some not, but then I ended up just removing the current and changing to new C-lines and its fine.
    It appears some clines work fine on DM500x etc, but not stable on openbox.
    Dont know why, but I had this confirmed from an Oscam guy.
    Its the CCcam emus not interacting as they were intended.
    Although it worked when you changed location.....
    Try the router with no network password first or a new CAT lead to boot.
  10. #25
    Nov 2013
    Hi.
    I got my openbox X10 set last year on October 13 with subscription 6months. I have renewed the subcription for another 1 year. However, after 5months+ my openbox continuously scrambled. Thought at first my internet connection got problem. But now, internet connection resolved but channel still scrambled. Youtube also unable to load. The funny part is when I played my openbox set at my friends place, tv channel was clear. I even tried my friends' openbox set, same model X10 from the same service provider at my place but still no channel. My friends sets works normal at my friends' place.
    So, my initial conclusion is my openbox set has blocked data from my particular modem at my home. I have tried change the cable but no use.
    Anybody can confirm the real problem? How to resolve? Even my service provider also clueless.
    Thanks in advance
  11. #26
    May 2011
    try purging ip address. set a static ip address outside range(192.168.100.xxx) once you've established static ip has been achived switch dhcp on to acquire an allocated ip from router.
  12. #27
    Oct 2014
    stoke on trent
    have you tried using a wireless aerial on it see if that picks it up.
    try testing your with a to make sure your isn't been used by some1 else etc
    Last edited by digicon; 31st October, 2014 at 02:33 PM. Reason: Read the Forum Rules Please
  13. #28
    digicon's Avatar
    Quote Originally Posted by webby06 View Post
    Your first stop should have been here: http://www.digital-kaos.co.uk/forums...rules-2/#post2
    • Linking to Card Sharing Payservers for any reason is not allowed
    • Discussions about Cardsharing are not allowed, including, but not limited to, CCcam, Oscam, MGcamd, Gbox, Mbox, etc....
    • Discussions about Servers, Providers, Clines, Gift's etc will be edited or removed.
    • No asking for lines.
