Results 1 to 7 of 7
    Jan 2012
    Default EGR Off Smart Four Two
    I already tried to switch.
    can someone confirm?
    after a while the car is in safe mode.
    switch not working
    ori and mod attached
    Apr 2012
    which ecu?
    Jan 2012
    hi
    0281010161 1037365258
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by xtreem View Post
    switch not working
    What error? Disconect the valve?
    waldi1979's Avatar
    Dec 2010
    Disconect EGR valve
    And try this file.
    DK Veteran ACDC's Avatar
    Feb 2011
    Quote Originally Posted by waldi1979 View Post
    And try this file.
    Is this file working? Has anyone tested?
    I'm trying it with another smart, and if I disconnect EGR I get a P1403 error code....is it normal to get EGR dtc-s when EGR is supposed to be turned off?
    EDIT: tested it, car won't go into limp mode even with EGR disconnected, and dtc stored. Looks like it's good enough
    Jan 2012
    And try this file.
    Hello
    thanks for the file.
