Results 1 to 15 of 30
    Feb 2011
    Barcelona, Spain
    Default MED 17 5.5 TC1766 locked after trying boot mode
    Hi everybody, I have EU galletto with 3 leds V48-103
    I have a med17 5.5 of a ibiza cupra 1.4 tsi, and I could get ID and galletto soft said that the ecu has got antituning protection and when I tried to read I didn't.
    Then I opened the ecu and I identify the processor, is a TC1766
    and I tried to do boot mode choosing TC1766 (soldering boot wire to pin to the correct pad of pcb) without succes.
    But when I tried to get ID by obd mode I couldn't and now the ecu doesn't work.
    Anybody knows what happened?
    Thank you.
    Seems like your clone get the ecu burnt.
    Please buy a new one.
    Another FG2 clone dead ECU - keep killing them guys!
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
    Feb 2011
    Barcelona, Spain
    How do you know that the ecu is dead for to do boot mode???
    I never broke an ecu doing boot mode!
    Quote Originally Posted by soplillo View Post
    there's always a first time for everything
    Top Poster rust55's Avatar
    Apr 2012
    Now read on OBD. Passat B6 TSI1.8 med17.5.5.
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    I don't think galetto did something wrong, using the boot mode protocol with the correct setup it should work, surely you made a mistake when you open it, or when you soldered/chose the pinout.
    Try to see if you can communicate in every way with it on the car.
    It is very easy to kill ecu if the soldering iron is not grounded, you tuch boot pin and procesor locks up forever in boot, you can figure out your self, read ecu without boot pin conected on table and you will see
    BTW. Galletto is not a tool for this job!
    Jul 2012
    BG
    call alientech and ask for assistance
    umoussa's Avatar
    Universe
    I have read MED17.5.5 with fgtech so smooth. Looks like you have incorrectly boot the ecu.
    But one important thing, did you measure the resistance between the grey and black wires before you read the ecu?
    Maybe your cable is not well configured
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
    DK Veteran Overtune's Avatar
    Quote Originally Posted by umoussa View Post
    +1 bootmode works 100% ok. Maybe your fault or did damage to ecu while trying to open...
    TUNING FILE SERVICE SINCE 2008
    Feb 2011
    Barcelona, Spain
    I'm sure that the ecu pinout is correct becouse I use the galletto manual and I choose the correct microprocessor and the correct ecu model.
    Before to did boot mode the ecu communicates with interface and identify.
    I checked the boot wire with a tester and it has got a 1k resistor.
    I use a regulated power supply with good voltage.
    I tried to read ecu without boot pin but the ecu it's locked.
  13. #13
    peko's Avatar
    you test boot mod pin with tester but with ecu ON 12V ?
  14. #14
    Feb 2011
    Barcelona, Spain
    Quote Originally Posted by peko View Post
    yes, checked.
  15. #15
    Feb 2011
    Barcelona, Spain
    New news, I could read the ecu with original k.tag of alientech, finally, the mistake was by my european galletto2.
