Results 1 to 7 of 7
    Top Poster + pl1976's Avatar
    Feb 2010
    Default Help with imgburn setting
    Can somebody help me please. Burnt some game downloads months ago which went spot on. But recently i had to format my computer and reinstall windows. Now i have lost all my settings. Trying to burn 007 legends but keep getting coasters expensive when its verbs. Can someone confirm a working setting so i can get a succesfull burn.
    DK Veteran m9g's Avatar
    Dec 2009
    I believe if you have an Ihas burner you can leave the settings as default apart form the obvious un-tick verify and burn at lowest speed.
    Mines set at default and discs burn fine
    You are running iso through abgx and loading the .dvd into imgburn to get the right layer break?
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
    Feb 2010
    Yep have ihas burner. That could be the problem not running them through abgx. When i clicked on the dvd file it just came up oops i will choose the correct file this time so must choose the iso file??
    Feb 2010
    Quote Originally Posted by m9g View Post
    Just tried they settings games are getting further but just crashing at menus. 007 forza horizon
    Feb 2010
    Just thinking will i maybe need to reflash the dvd drive? As i restored my computer and put a new copy of windows on?
    Dec 2009
    Quote Originally Posted by pl1976 View Post
    No you wont have to re-flash the drive, the flash will overwrite the pre-installed firmware which is a read only firmware so wont be wiped when you re-install windows.
    Just looked and Forza Horizon is verified in the ABGX database, Look online for ABGX settings and change them, run the iso through ABGX which will create the .dvd file, open imgburn, untick verify, click on open folder and choose the .dvd file and burn at 2x speed.
    These settings are based on the fact that you are using verb discs? i believe if you are using a lower grade disc then settings in imgburn will have to be changed - you'll have to ask someone else about that as I only use verbs so no need to change anything.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    All you will need to do is download and instal abgx. Sounds like topology data is missing to me.
    Basic settings should cover this, if not i will post settings you need
