check this dump end send raport
ecusafe 2 and volta not work on this cars, only erased ALL DTC's
ok i reprogrammed with this software and i thought all was good as soon as it started revved up over 3000rpm no problem so i take for drive and only rev to 3000rpm again. so i realise now that when i start car only rev up for 1st 2 or 3 secs then back to limp any suggestions please..??
try and report, pass in PM
have you dtc in ecu?
have you post ORI file or ECUSAFE file???
Post ORI file and i think i can help you.
Mb is very easy soft to dpf off but no ecusafe tuners....
And your diferential pressure sensor must be ok (working condition)
You remove DPF from car (hardware)?
Im here to help and to be helped
best way for solusion is mercis opinion.write again ori file and post your dtc codes.
