    Top Poster stylus's Avatar
    Feb 2009
    turn turn left at the end of the world
    Default r4ds not working.
    got r4 with games added tried to copy and paste on second sd micro
    which is same as r4 got in it copied succesfull on to com
    transfered to other micro succesfull just says loading all the time on ds.
    any advice please thk's
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    What size of micro sd card. Original R4s are limited to 2gb mem card.
    Are on the firmware files needed on the root of the card and not in a folder.
    There should be 2 folders and 3 files for the firmware. Then any games after that, the games can be in a games folder if you want though.
    Feb 2009
    Hi jaffa
    everything copied on second 2gb card but still stuck on loading screen
    thanks stylus
    Feb 2009
    try formatting the card first then copy the system files. try to boot it up with no games installed if all goes well, there might be a game that is corrupted.
    Mar 2008
    Norn Iron
    Do as said above, format and just put the firmware on the mem card....NO games.
    You should have. 2 folders then 3 files.
    _system_
    Moonshl
    _DS_MENU.DAT
    _DS_MENU.SYS
    _DS_MSHL.NDS
    Feb 2009
    Thanks guy's it was the game file's
    now to find game's
    thak you again.
