Page 6 of 8 FirstFirst 12345678 LastLast
Results 76 to 90 of 107
  1. #76
    Jul 2011
    hello guys,
    does anyone of you have the OLS247.dll for this particular version here? anyone willing to share? i don?t care if its a registered user or not, the notebook its installed on will never be connected to the internet in any kind of way.
    thanks and kind regards
  2. #77
    Member rewalex's Avatar
    Aug 2013
    Mallorca, Spain
    Quote Originally Posted by xumbazio View Post
    Hello m8's
    Anyone managed to run Winols 2.24 on Windows XP mode?
    It reply s this program can't run under Virtual PC
    Any ideias?
    Thanks in advanceAttachment 218935
    Add to file WindowsXP.vmx
    missing threads. Working on Vmware 100% . I use it whiteout problems.
    .encoding = "windows-1251"
    config.version = "8"
    virtualHW.version = "9"
    scsi0.present = "TRUE"
    memsize = "512"
    scsi0:0.present = "TRUE"
    scsi0:0.fileName = "Windows XP Professional.vmdk"
    ide1:0.present = "TRUE"
    ide1:0.fileName = "auto detect"
    ide1:0.deviceType = "cdrom-raw"
    floppy0.fileType = "device"
    floppy0.fileName = ""
    floppy0.clientDevice = "FALSE"
    ethernet0.present = "TRUE"
    ethernet0.connectionType = "bridged"
    ethernet0.wakeOnPcktRcv = "FALSE"
    ethernet0.addressType = "generated"
    usb.present = "TRUE"
    ehci.present = "TRUE"
    ehci.pciSlotNumber = "35"
    sound.present = "TRUE"
    sound.fileName = "-1"
    sound.autodetect = "TRUE"
    mks.enable3d = "TRUE"
    serial0.present = "TRUE"
    serial0.fileType = "thinprint"
    pciBridge0.present = "TRUE"
    pciBridge4.present = "TRUE"
    pciBridge4.virtualDev = "pcieRootPort"
    pciBridge4.functions = "8"
    pciBridge5.present = "TRUE"
    pciBridge5.virtualDev = "pcieRootPort"
    pciBridge5.functions = "8"
    pciBridge6.present = "TRUE"
    pciBridge6.virtualDev = "pcieRootPort"
    pciBridge6.functions = "8"
    pciBridge7.present = "TRUE"
    pciBridge7.virtualDev = "pcieRootPort"
    pciBridge7.functions = "8"
    vmci0.present = "TRUE"
    hpet0.present = "TRUE"
    usb.vbluetooth.startConnected = "TRUE"
    buslogic.noDriver = "FALSE"
    displayName = "Windows XP Professional"
    guestOS = "winxppro"
    nvram = "Windows XP Professional.nvram"
    virtualHW.productCompatibility = "hosted"
    powerType.powerOff = "hard"
    powerType.powerOn = "hard"
    powerType.suspend = "hard"
    powerType.reset = "hard"
    extendedConfigFile = "Windows XP Professional.vmxf"
    scsi0.pciSlotNumber = "16"
    ethernet0.generatedAddress = "00:0C:29:13:A4:0B"
    ethernet0.pciSlotNumber = "33"
    usb.pciSlotNumber = "32"
    sound.pciSlotNumber = "34"
    vmci0.id = "-1626102773"
    vmci0.pciSlotNumber = "36"
    tools.syncTime = "FALSE"
    uuid.location = "56 4d 02 0b 41 4f e5 ce-da 23 76 9f 9f 13 a4 0b"
    uuid.bios = "56 4d 02 0b 41 4f e5 ce-da 23 76 9f 9f 13 a4 0b"
    cleanShutdown = "TRUE"
    replay.supported = "FALSE"
    unity.wasCapable = "FALSE"
    replay.filename = ""
    scsi0:0.redo = ""
    pciBridge0.pciSlotNumber = "17"
    pciBridge4.pciSlotNumber = "21"
    pciBridge5.pciSlotNumber = "22"
    pciBridge6.pciSlotNumber = "23"
    pciBridge7.pciSlotNumber = "24"
    usb:1.present = "TRUE"
    ethernet0.generatedAddressOffset = "0"
    tools.remindInstall = "TRUE"
    vmotion.checkpointFBSize = "134217728"
    softPowerOff = "FALSE"
    usb:1.speed = "2"
    usb:1.deviceType = "hub"
    usb:1.port = "1"
    usb:1.parent = "-1"
    floppy0.autodetect = "TRUE"
    ide1:0.autodetect = "TRUE"
    usb.autoConnect.device0 = ""
    floppy0.startConnected = "FALSE"
    monitor_control.virtual_rdtsc = "false"
    monitor_control.restrict_backdoor = "true"
    isolation.tools.getPtrLocation.disable = "true"
    isolation.tools.setPtrLocation.disable = "true"
    isolation.tools.setVersion.disable = "true"
    isolation.tools.getVersion.disable = "true"
    monitor_control.disable_directexec = "true"
    checkpoint.vmState = ""
    ide1:0.startConnected = "TRUE"
    usb:0.present = "TRUE"
    usb:0.deviceType = "hid"
    usb:0.port = "0"
    usb:0.parent = "-1"
    ide0:0.present = "FALSE"
  3. The Following 2 Users Say Thank You to rewalex For This Useful Post:
    ohkarol (22nd September, 2013), xumbazio (12th September, 2013)
  4. #78
    May 2013
    Quote Originally Posted by rewalex View Post
    memsize = "512"
    scsi0:0.redo = ""
    usb:1.speed = "2"
    usb:1.port = "1"
    usb:1.parent = "-1"
    usb:0.port = "0"
    usb:0.parent = "-1"
    Ok, but that solution is for VMware...i'm using Windows Virtual PC (XP mode for Windows7)
    My *.vmc file contains the following:
    <?xml version="1.0" encoding="UTF-16"?>
    <!-- Microsoft Virtual Machine Options and Settings -->
    <preferences>
    <version type="string">2.0</version>
    <event_logging>
    <preference_change>
    <enabled type="boolean">false</enabled>
    </preference_change>
    </event_logging>
    <hardware>
    <bios>
    <base_board>
    <serial_number type="string">4547-7354-3738-3191-4920-5020-46</serial_number>
    </base_board>
    <bios_guid type="string">{22C4FBCF-A571-4986-AD9D-2D6DB384DB83}</bios_guid>
    <bios_serial_number type="string">4547-7354-3738-3191-4920-5020-46</bios_serial_number>
    <chassis>
    <asset_tag type="string">9697-7267-7832-9640-6199-8046-47</asset_tag>
    </chassis>
    <cmos type="bytes">00004000F020378002FFFF2F00FF3F1000003 F00000000000031004C07070707065CFFFF208580FF0300000 0200C01800CFC00000000000000000000000000901A32E2525 80050E999E62401002784004A2080240000000000085AACFE1 032547698BAE40000000000000300000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000</cmos>
    <time_bytes type="bytes">52002200000005130913</time_bytes>
    </bios>
    <memory>
    <ram_size type="integer">1024</ram_size>
    </memory>
    <pci_bus>
    <ethernet_adapter>
    <controller_count type="integer">1</controller_count>
    <ethernet_controller id="0">
    <ethernet_card_address type="bytes">0003FF94E98B</ethernet_card_address>
    <id type="integer">0</id>
    <virtual_network>
    <id type="bytes">01010101010101010101010101010101</id>
    <name type="string">Funcionamento em Rede Partilhado (NAT)</name>
    </virtual_network>
    </ethernet_controller>
    </ethernet_adapter>
    <video_adapter>
    <vram_size type="integer">16</vram_size>
    </video_adapter>
    <ide_adapter>
    <ide_controller id="0">
    <location id="0">
    <drive_type type="integer">1</drive_type>
    <pathname>
    <absolute type="string">C:\Users\C?tia\AppData\Local\Microso ft\Windows Virtual PC\M?quinas Virtuais\Windows XP Mode.vhd</absolute>
    <relative type="string">.\Windows XP Mode.vhd</relative>
    </pathname>
    <undo_pathname>
    <absolute type="string" />
    <relative type="string" />
    </undo_pathname>
    </location>
    </ide_controller>
    <ide_controller id="1">
    <location id="0">
    <drive_type type="integer">2</drive_type>
    <pathname>
    <absolute type="string">E</absolute>
    </pathname>
    </location>
    </ide_controller>
    </ide_adapter>
    </pci_bus>
    <standard>
    <name type="string">Virtual PC 7</name>
    <version type="string">0001.0000.0000</version>
    </standard>
    <super_io>
    <floppy id="0">
    <pathname>
    </pathname>
    </floppy>
    <parallel_port>
    <port_type type="integer">0</port_type>
    </parallel_port>
    <serial_port>
    <connect_immediately type="boolean">false</connect_immediately>
    </serial_port>
    <serial_port id="0">
    </serial_port>
    <serial_port id="1">
    </serial_port>
    </super_io>
    </hardware>
    <integration>
    <microsoft>
    <folder_sharing>
    <load_allowed type="boolean">false</load_allowed>
    </folder_sharing>
    <heartbeat>
    <failure_attempts type="integer">12</failure_attempts>
    <failure_interval type="integer">10</failure_interval>
    <rate type="integer">10</rate>
    <time type="integer">60</time>
    </heartbeat>
    <host_time_sync>
    <enabled type="boolean">true</enabled>
    <frequency type="integer">15</frequency>
    <threshold type="integer">10</threshold>
    </host_time_sync>
    <mouse>
    <allow type="boolean">true</allow>
    </mouse>
    <version>
    <additions_number type="string">14.1.7600.16403</additions_number>
    <guest_os>
    <build_number type="string">5.01.2600</build_number>
    <computer_name type="string">VirtualXP-67123</computer_name>
    <long_name type="string">Windows&amp;reg; XP Professional</long_name>
    <revision_number type="string">Service Pack 3</revision_number>
    <short_name type="string">Windows&amp;reg; XP Professional</short_name>
    <suite_name type="string" />
    </guest_os>
    </version>
    <video>
    <user_selected>
    <depth type="integer">16</depth>
    <height type="integer">480</height>
    <width type="integer">640</width>
    </user_selected>
    </video>
    </microsoft>
    </integration>
    <properties>
    <creator>
    <build type="string">6.1.7601.17514</build>
    <name type="string">Virtual PC</name>
    </creator>
    <modifier>
    </modifier>
    </properties>
    <settings>
    <configuration>
    <next_id type="integer">1</next_id>
    <saved_state>
    <path>
    <absolute type="string">C:\Users\C?tia\AppData\Local\Microso ft\Windows Virtual PC\M?quinas Virtuais\Windows XP Mode.vsv</absolute>
    <relative type="string">.\Windows XP Mode.vsv</relative>
    </path>
    </saved_state>
    </configuration>
    <disks>
    <track_disk_cache>
    </track_disk_cache>
    </disks>
    <globalconfigid type="string">{F739548A-503A-4780-A380-0A48BD65EE5B}</globalconfigid>
    <host>
    <resource_control>
    <cpu>
    <host_processors type="integer">1</host_processors>
    </cpu>
    </resource_control>
    </host>
    <notes type="string" />
    <shutdown>
    <quit>
    <action type="integer">0</action>
    </quit>
    </shutdown>
    <sound>
    <sound_adapter>
    <enable type="boolean">true</enable>
    </sound_adapter>
    </sound>
    <undo_drives>
    <always type="boolean">false</always>
    <default_action type="integer">1</default_action>
    <purposely_kept type="boolean">false</purposely_kept>
    <use_default type="boolean">true</use_default>
    </undo_drives>
    <video>
    <enhanced_mode type="boolean">true</enhanced_mode>
    <full_screen type="boolean">false</full_screen>
    </video>
    <guest_os type="integer">3</guest_os>
    </settings>
    <virtual_machines>
    <allow_packet_filtering type="boolean">false</allow_packet_filtering>
    <allow_promiscuous_mode type="boolean">false</allow_promiscuous_mode>
    </virtual_machines>
    <ui_options>
    <onclose_showmessage type="boolean">true</onclose_showmessage>
    <onclose_defaultaction type="string">save</onclose_defaultaction>
    <cred_id type="string">VirtualXP-67123</cred_id>
    <dynamicdrives_redirection type="boolean">true</dynamicdrives_redirection>
    <share_drives type="string">*</share_drives>
    <audio_redirect type="boolean">true</audio_redirect>
    <vxp_setup_complete type="boolean">true</vxp_setup_complete>
    <guest_rail_enabled type="boolean">true</guest_rail_enabled>
    <window_xpos type="integer">162</window_xpos>
    <window_ypos type="integer">75</window_ypos>
    <resolution_height type="integer">599</resolution_height>
    <resolution_width type="integer">960</resolution_width>
    <dvd_none type="boolean">false</dvd_none>
    <use_enhancedmode type="boolean">true</use_enhancedmode>
    <share_clipboard type="boolean">true</share_clipboard>
    <share_printer type="boolean">true</share_printer>
    <smartcards type="boolean">true</smartcards>
    </ui_options>
    <multi_channel type="boolean">true</multi_channel>
    <vm_state_rail>
    <virtual_applications_exist type="boolean">false</virtual_applications_exist>
    </vm_state_rail>
    </preferences>
    Do you know the option to change for "disguise" virtual PC in this file?
    Best regards
  5. #79
    hello,
    is it possible to install it also on another drice than "C"? for example partition "D"?
    it only works with my pc if i install it on C, is there a chance to install it on another drive?
  6. #80
    the most easy installation is metod 1, but the ok install is this:
    1 - install winols 2.14 demo
    2 - push setup.exe in windows xp or righ button like administrator in windows 7
    3 - "remove ols icon" from desktop
    4 - copy this 3 files: EVC key.dll - EVClicenseMOD.dll - winols.exe.... (from crack) to "C: program files/evc" (not intro in WINOLS) and send "winols icon" to desktop
    5 - run winols icon
    the first time is write "REGISTERED CAR TO LINK" for crack ok
    run second time and you will have winols 2.24 working 100% ok with checksum ok
    best regards
  7. #81
    Top Poster + bts's Avatar
    electronic world
    The new version should WinOLS.
    Car electronics technician
    I use devices
    Devices:
    Ktag(Master),Fgtech2(Master),KessV2(master),Gallet to1260,KWP2000,BDM100,Elnec(Beeprog),CDP+,Carprog, KTS550,FSA751,Launch(X431),ELM327....
  8. #82
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    with method 1 work perfect on win XP .
  9. #83
    Jun 2012
    Quote Originally Posted by bts View Post
    WinOLS 2.24 Download working link
    +++ Thanks Button
    Hello, link not working....
  10. The Following 5 Users Say Thank You to cawadany For This Useful Post:
    apeet (25th March, 2021), goyjim (19th April, 2014), iRiKi (18th May, 2018), mocki (17th August, 2014), SALLITY (8th August, 2021)
  11. #84
    My winols closes immediately if i change a map, anyone have this problem too?
  12. #85
    Apr 2014
    Hounsland
    I need mitsubishi colt turbo damos please!
  13. #86
    May 2014
    UK
    Could you please put it again on hotfile or somewhere else an offer us the link again. The link here is from 2009 and it expired. If you have the cracked version with check it would be awsome!!!! Many thanks!!!!
  14. #87
    inyxon's Avatar
    Spain
    Hi Friends... I have tried to install... Downloaded winols 3.15 from evc and when I try to open crack version, open but not possible to load files...
  15. #88
    May 2016
    Thanks for your work
  16. #89
    May 2016
    thanks friend
  17. #90
    Jan 2016
    Hi Mates
    Can someone help me with checksum, I want to use winols just for checksum, and it is my first time.. I have ver. 2.24
    when I open new project winols shows this message..I m following all these steps but no luck
    please tell me how to chk correting by winols ( dump is from ducato edc15c7)
