Page 143 of 200 FirstFirst ... 4393133138139140141142143144145146147148153193 ... LastLast
Results 2,131 to 2,145 of 2987
  1. #2131
    Meat-Head's Avatar
    Tonight
    still got these aftermarket chest pains , going for obd scan end of week
    tonight, looked at a lump of metal, mean to suck, squeeze, bang, blow, but
    apears to be only partly ducking, no squeezing, no bang and just blow
    Phoned weird friend, he done the proclaimers, drove 500 miles, got there, see not done what they meant to have done
    got in his car, drove the 500 miles back, sent in big bill for wasted day, fuel macdonalds etc
    laters, meat
  2. #2132
    Meat-Head's Avatar
    Tonight, had fun playing with myself in the garden for two hours.
    got the fuel tank back in place, noticed that Herman the German back in
    1981 drilled a rather convenient hole.
    gets piece of random boiler case, fits perfect, cuts it down with grinder
    butvmanagez to cut wrong part.
    so stuffs but of foam rubber in says nothing.
    got the fuel filler neck back in, shoved blow torch in hole,lined with sticky aluminium foil
    went to tesco got beers, bath, dK now heavy-r.com need a video on setting the pointing things with 20,000 volts electricity
  3. #2133
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    crazy people all around the world
  4. #2134
    Meat-Head's Avatar
    Quote Originally Posted by galaxy0634 View Post
    You met
    my weird friend I didn't want and both imhabary friends of mine then!
  5. #2135
    Meat-Head's Avatar
    Faulty, had a tug at work, chest went tight, mid tug
    was going from lock to lock, looking for a piece of fine crack.
    feels like saucer in middle of my chest since.
    Going to Abdul chipshop for Aadvarks and chips.
    could do with playing with myself in garden.
    i. Have already put some of that white sticky stuff I have on the tip of my thing
    then put it inside the long hard stiff shaft I have, with drop of glue.
    this in turn has direct connection to the thermostat
  6. #2136
    Meat-Head's Avatar
    UPDATE:-
    went to abdul, ended up with something sold as fish
    then pigged that.
    started to play with myself, realised piece of paper in the hoose.
    so unscrewed the pressure switch, either screw ready missing or I lost one without moving.
    did that, then just as getting dark, drilled a hole, to find 3mm to far over, so poundland epoxy gland on.
    nothng exciting only mains electrify and ware,r no worrys
    chedt feels like disc on it
  7. #2137
    Meat-Head's Avatar
    TONIGHT:/
    found the screw that dropped last night, poured some more poundland epoxy on the other side of my gland.
    got the other high pressure pump built back up. Cut rubber pipe and now smell like a plant fitter
    Stocked up on chocolate viewing ~~~~
  8. #2138
    Second run of the week in the evening, burn an operating system into cd while me running,
    plan to install OS no idea when , plan to fix no start car in 1 year.
    Waving to all the people in this thread.
  9. #2139
    Meat-Head's Avatar
    Quote Originally Posted by alessioblaupunkt View Post
    , plan to fix no start car in .
    Yeah same here
    ON TOPIC:-
    far fruends, tesco, p0rn bath bed
  10. #2140
    Meat-Head's Avatar
    Weird friend, bottle of sticky stuff, can of brake cleaner and pub if goes to plan
  11. #2141
    Meat-Head's Avatar
    Ok so why are the last few hours of a weekend more productive than entire weekend?
    managed to clear the blockage in my discharage orrfice, the pump seems to have recovered.
    connects the lance up, noddles iShit middle blocked solid with ferrous oxide.
    Turned the offloaded valve to far and blew the lance and welded the relay contacts solid!
    so my juices come out the side, cuts the hard solid shaft thing off with angle grinder
    decides, to try soldering instead of welding, gaping great hole, no worries, pin pr1ck what a nightmare
    so hopefully get the diesel in tomoriee and hope the cinder iShit china level switches don't leak
  12. #2142
    Meat-Head's Avatar
    Tonight, ran out of energy, chest pains. Getting less, be still actuve
    rebuilding machine still, the other one as too wet iutside
  13. #2143
    Meat-Head's Avatar
    Tonight, swapping one of them Victorians designed thing to install
    but still can't fill with diesel, as will make me smell like a plant fitter
    need to be clean for tomorrow
  14. #2144
    ifred's Avatar
    Hi Meaty wanted to pm you but your inbox is crammed! How did you OBD scan go? Hope it was positive and your on the mend
    Ifred
  15. The Following User Says Thank You to ifred For This Useful Post:
    Meat-Head (15th August, 2018)
  16. #2145
    Meat-Head's Avatar
    UPDATE TO LAST NIGHT:-
    put my finger up the back of ma shitter, actually got 3 holes, poked hose pipe up each side one and it exits into the main arena. So next step is to make 3 way connection see if connecting that to my pump works.
    TONIGHT:-
    burger and chipz, then plant fitter smells.
    need to find why got 43VAC between washing machine case and the kitchen sink.
    Quote Originally Posted by ifred View Post
    Ifred
    Yez pm pm is full has been for years, once cleared just get nothing but trash about Ingrowing toenails and dead cats stuck up trees. If you swap my name around, hotmail here in uk.
    yez went to hospital, with my chest and the rest of my body, doctor decided my giblets
    are working, did egr scan and sent me on my way
    no heart problems (except when pricing jobs) revered back to doctors.
    she did say I'm not dead and can view dK, so no worrys.
    She did dK search and noticed in 2013 simular chest pains.
