Page 169 of 200 FirstFirst ... 69119159164165166167168169170171172173174179 ... LastLast
Results 2,521 to 2,535 of 2987
  1. #2521
    Meat-Head's Avatar
    Tonight, subject to atmospheric conditions might be jamming my fingers in a black oily hole
    or resealing my crack, once opened it up
  2. #2522
    May 2019
    isle of skye
    alot of cracks your filling
  3. The Following User Says Thank You to smokin66 For This Useful Post:
    Meat-Head (11th July, 2019)
  4. #2523
    Meat-Head's Avatar
    Yes pumped my crack with silicon sealer, filled with Poundland draft excluder first
    then, let it skin over, and scewed like merry hell
  5. #2524
    Meat-Head's Avatar
    Tonight weird friend bbq. Need to whip my hose out
  6. #2525
    Meat-Head's Avatar
    Greased my shafts, got hot, jambed male into female
    hope dont seize again
  7. #2526
    Meat-Head's Avatar
    Tonight ramming my male part into the badly splayed female part, ended up cutting
    with angle grinder to get it off, so hopefully a clamp will do, got some exhaust paste somewhere
  8. #2527
    Meat-Head's Avatar
    UPDATE:-
    fixed table lamp for naybour, soldered tv board for thick friend
    trued to close my gash up, proper crooked
  9. #2528
    Meat-Head's Avatar
    Impersonate scarlet pimplenell, both sides of toon at once
  10. #2529
    Meat-Head's Avatar
    Knackered, going to shout obscenities doon blower then play with myself in the garden
  11. #2530
    Meat-Head's Avatar
    Painted my long hard shaft black, then lacquered it.
    buggered if could find pry bar, chisel or punch earlier
  12. #2531
    Meat-Head's Avatar
    Well tonight, got my ringpiece hot, then hammered it on the the bussness end of my shaft, had to coat my end in grease
    then ring piece went cold and hard, so warmed it up, then hammered it on more, you can see the end of my ring piece has been hammered, but not got a copper/hide mallet
    then flicks my shaft up and lost one of my huts in the long grass , unable to find it
    then I remembered that I have more than one nut, so used that instead.
    once shaft happy, I rammed it in the black hole it lives in, and locked it in its little housing, and just needs a little more screwing.
    Tomorrow I’m hoping to have a good old blow in my tank, got about 35 litres of juice init.
  13. #2532
    Meat-Head's Avatar
    Last nite, blow my tank got a load on floor, only a egg cup full.
    TONIGHT:-
    lieing on my back, taking photos of my undercarriage and sending to a stranger
  14. #2533
    Meat-Head's Avatar
    Update
    tightened my nuts up, one slightly loose, but grab the shaft it’s attached to and solid
    then ended up squirting some white sticky stuff on my undercarriage
    1/2 can left, amazed how little it covers.
    then ended up with a right turd, came running out one of my holes, faster than fresh shit off a greasy shovel.
    will try and steam clean it off another time, most of it that went down my leg came off with white spirt
  15. #2534
    Meat-Head's Avatar
    Tonight, playing with my self and sweating like a pig
    be be changing my bodily fluids, been minging in there two days, just hope not rotted my rubbers
  16. #2535
    Meat-Head's Avatar
    Update:-
    looking into my hole, which is quite wide, enough for a couple of fingers, you can clearly see what white bits.
    i’m guessing that’s it’s the Tesco washing machine cleaner not fully dissolved.
    tried flushing it out 3 times, using that sucky thing, but still white bits in there.
    used hose pipe, gave it large, still white bits.
    at least the liquid coming out into the bucket is no longer red or pink.
    think the heater matrix must hold about 4 litres on its own
