Results 1 to 4 of 4
    Nov 2011
    Default Delco 12200411 V8 PCM
    Can anyone help with a cost effective way to read these PCM flash data via obd plug?
    You can get the interface a software from
    HPTuners.com >> Performance At Your Fingertips
    Anyone done it a different way?
    Cheers
    Nov 2012
    smartville in front of a OBDplug
    if you have no knowledge of about to find each map in a flash file the i think hptuner solution it the best for you
    Jun 2012
    Efilive is also a great product for these ecu's
    Tunercat from moates.net. if you're doing many, it's 10x cheaper.
    Sent from my DROID RAZR using Tapatalk 2
