Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Hybrid View
    DK Veteran jovime's Avatar
    Nov 2010
    Chipland
    Default WinOLS 2.24 changing views solution
    Hi guys!
    Trying to find a solution for changing between views when pressing cursor, uppercase, ctrl or alt keys, I think I've found it.
    As proel stated, next steps 1-2 could be unnecessary, just select Misc --> Configuration --> Debug --> Delete configuration, restart.
    Here's the old method
    1) Install last WinOLS demo you can find on EVC website, and run it 1 time (don't uninstall it).
    2) Install Winols 1.7 and run it 1 time, it will warn about config file is created by a newer version and default settings will be used (don't uninstall it).
    3) Then install WinOLS 2.24 (method 2) as you can find in this post http://www.digital-kaos.co.uk/forums...g-link-302035/ (thx to bts).
    WinOLS will prompt first time configuration window. Just configure it as you like and voil?!
    Thanks if it worked for you!
    Kind regards!
  2. The Following User Says Thank You to jovime For This Useful Post:
    jm6734 (2nd January, 2019)
  3. #2
    Sep 2010
    Unnecessary steps 1-2. Step 3. Misc --> Configuration --> Debug --> Delete configuration, restart.
    Nov 2012
    smartville in front of a OBDplug
    2.34 has been released to fix lot bugs
    Nov 2010
    Chipland
    Quote Originally Posted by kennfeld View Post
    Post it
  6. #5
    Nov 2012
    who should been intrested in more dll's checksums etc ?
  7. #6
    Nov 2012
    it's not possible to post it official version with my customer id inside ....
  8. #7
    May 2010
    how wopld I add more checksums if I have them
  9. #8
    Nov 2012
    Quote Originally Posted by Craven_pwr View Post
    checksums with the same customer code matching to the 2.24 version will work if you put them in
    prog files/evc/winols/dlls
    if you install dlls for another id or version they should been ignored
  10. #9
    Mar 2011
    I think than this sofwtare not work with w7 64bits.
  11. #10
    Feb 2013
    Quote Originally Posted by alcorte View Post
    it works in my case perfect with win7 x64
  12. #11
    Mar 2009
    Quote Originally Posted by cruuz View Post
    I also have it working with win7 64bit no problems.
  13. #12
    Nov 2010
    Chipland
    Quote Originally Posted by m3evo View Post
    Can you post or link or send me a PM with the loader for x64?
  14. #13
    Jul 2008
    romania
    Quote Originally Posted by jovime View Post
    i need it to
  15. #14
    Dec 2009
    VENICE
    quote no problem with 64bit
  16. #15
    Maartinj's Avatar
    Nov 2010
    Poland
    Also win 7 32BIt problem.
