Page 1 of 6 123456 LastLast
Results 1 to 15 of 81
    DK Veteran mathura's Avatar
    Aug 2011
    Default CALIBRATION FILE ISM
    Hello Friends
    Please I need Cal File for Cummins ISM ECM
    ESN: 34974270
    ECM P/N : 3681405
    The engine rpm increases to 1200 rpm without toching the accelerator pedal afer running for about 5 mins and would not return to idle speed
    NO CODES thrown by ECM
    Any help is appreciated
    DK Veteran Poptest's Avatar
    Sep 2010
    Quote Originally Posted by mathura View Post
    Hello Friends
    ESN: 34974270
    ECM P/N : 3681405
    Injectors are worn out. ECM is not able to control faulty injectors.
    Aug 2010
    Russia
    Injectors do not work
    Aug 2011
    Thanks for the response but I am still looking for cal file, I will try and see if I test with another ECM but I do not have one at the moment.
    Calibration File needed for ISM
    Engine SN: 34974270
    Sep 2010
    Engine SN: 34974270
    Hi Mathura,
    Calibration file for your ESN is in Incal. Do you have Incal?
    Attached is old Service Parts Topic 95T6-6 regarding Idle rpm creep. Although this topic covers Celect & Celect Plus injectors, design of ISM injectors are very similar. Spill port erosion inside the injectors is the most common cause of idle creep. We have seen this many times.
    I also believe that recalibrating the ECM will not fix the problem.
    Good luck my friend...
    Jun 2012
    RUSSIA
    Engine SN: 34974270
    L21282.14 - this your cal code. Old code L20836.23 SC02455 FUEL Code XG69
    Aug 2011
    Quote Originally Posted by qalla75 View Post
    I will check code that is present in the ecm today
    Aug 2011
    ISM Cal file needed
    ESN: 34974270
    ECM Code: L20836.02
    Aug 2011
    Quote Originally Posted by Poptest View Post
    UPDATE:
    You were quite correct Poptest. The injectors were indeed the probelm, changed all six and engine now works great, idle speed now 650rpm.
    Thank you so much
    if do you have access to qsol go to https://quickserve.cummins.com/qs2/p...load_form.html there you can download any calibration ;P just put the ESN and the Calibration Code that you want pm if you want some help in this way to download a cal
    Sep 2010
    Hi Mathura,
    I'm glad your problem is fixed. This is what DK is all about...helping each other.
    Your posts have helped me too...
    Aug 2011
    Quote Originally Posted by Belefronte View Post
    Thanks for the information but I don't have access to QSOL some good brothers who has access always help.
    Great Forum
  13. #13
    Great Forum
    The ECM code for this engine is not available when trying to download from quickserve. When you view the data sheet for calibration updates on the engine serial#, it also shows a different ECM calibration then you posted that you can't download without the correct ECM code? The engine serial # and ECM code have to match or you get an error message. A02028.XX is the cal the engine calls for. It looks as though this ECM is from a Marine application and won't be usable on a highway vehicle?
    Almost every calibration update for this engine serial# is for "Idle surge fix" I'm sure the injector change out was all you needed. Poptest knows his engines from the posts he's made.
  14. #14
    Aug 2011
    Hello Friends
    Please for calibration file for Cummins M11 Engine
    Engine SN: 34830564
  15. #15
    Senior Member kitty-hawk's Avatar
    FRANCE
    Hello Friends
    Engine SN: 34830564
    Have you the ECM code ? or number of calibration ?
