Results 1 to 3 of 3
Thread: PEUGEOT 206
    Default PEUGEOT 206
    05 reg, engine management light on, diag fault codes. turbo pressure signal high turbo pressure sensor raw signal. permenant fault. will not clear, car driving fine, does anyone no what this fault means. thanks
    Meat-Head's Avatar
    THINK the lttle rubber pipe on map sensor full of crap, or sensor, had turbo do that
    DK Veteran teuton's Avatar
    Mexico
    If it's an 3 wire circuit with reference voltage an open in the ground wire will give you high signal voltage all the time. ( If this ground is shared with other sensor you'll gonna have the same there) Did you actually measure the pressure with a gauge?
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
