Results 1 to 4 of 4
    DK Veteran brad123's Avatar
    Dec 2011
    France
    Default help activation diagbox v6.01
    hi everyone, I received my diag tools today is I can not I install a diagbox v6.01, I try to patch found on my forum toujour such at the time of activation he told me (can not install error diagbox etc ...) if someone could help me it would be great ery, or mieu me install it via teamviewer.
    thank you in advance
    Jan 2011
    Quote Originally Posted by brad123 View Post
    Error... which numer of error?
    Some months ago I've error 0 when I've try to install DB on my netbook directly to XP. Then I've try to install DB on VirtualBox (of course Win XP), and everything's good...
    Step by step, I realized that the problem is the network connection.
    My post:
    PSA DiagBox V6.01
    OK, now I have got activated DiagBox 6.22.
    My solution is simple - if you have the same problems as me - Failure of the activation (error 0) try to reinstall Windows XP, do not install the drivers for Bluetooth and WiFi. Just install the drivers for the LAN (if those drivers are not already installed) and connect to the internet via LAN (RJ-45 cable) then install DiagBox (v6.01) patch, activate, update (e.g. v6.22 or newest), and then that's all. After that, make sure DiagBox works.
    Now you can install the other drivers, and disconnect from the Internet from LAN and connect to the Internet via WiFi - on my laptop it works.
    So, write the number of error, or try to install DB from VirtualBox from XP.
    i have the same probleme the error is error 0
    Dec 2011
    France
    Hi to all fellow for the delay, my problem is solved, I uninstall db6 and re - install a new patch v6 with, and everything works perfectly, tested on jumper 3,307 and xsara.
    Nice day
