Single switch only is not enough
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Ecusafe, Volta, Swiftec is working?
Only Winols?
Ecutuners sey: " Single switch only is not enough"
But http://www.digital-kaos.co.uk/forums...ml#post1420089
Maybe he mean to disconnect DPF ECU (under back seat) and clear DTC table
Single switch solution work for me- with disconnected DPF ECU
Im here to help and to be helped
wat ecu? edc16c34?
switch mode work good on psa 1.6
on ford 1.6 yes, on peugeout or citroen one single switch solution don't work good, there are 2 other switch to change
