Thread: openbox c4
    Default openbox c4
    Does anyone know anything about the openbox c4.
    I believe it is a cable box,andwas just wondering if it was another alternative to the kryptview and starview.
    Nov 2010
    Dont know about that box even so I dont think its an alternative for krytview or starview.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    Detailed Product Description
    1080P Satellite Receiver Openbox C4S HD
    1.DVB-C
    2.support CCcamd, Newcamd, MGcamd
    3.1080P HDMI
    1080P Satellite Receiver Openbox C4S HD:
    Main function:
    1) Fully Compliant with MPEG-2, MPEG-4/H.264 and DVB-C standard
    2) USB2.0 to Realize PVR
    3) HDMI output 1.4 Supported
    4) Easy Menu system with Multi-language and 65536 colored on screen display.
    5) 576P, 720P, 1080P video resolution & automatic PAL/NTSC conversion supported
    6) 5000 channels capacity & last channel memory supported
    7) 7 days electronic program guide (EPG) & picture in Graphics (PIG) supported
    8) Subtitle in DVB EN300743 and EBU supported
    9) Teletext in DVB ETS3000472 by VBI & OSD supported
    10) 32 different favorite groups optional & parental lock supported
    11) Network / Blind / Auto channel search optional
    12) Various channels editing functions (favorite, move, lock rename and sort) supported
    13) Software upgrade through USB/ Ethernet/ RS232 optional
    14) Games: Terris, Othello, Sokoban supported
    15) Smart Card Reader
    CPU
    CHANNEL DEMODULATION
    CPU Frequency
    324MHz (Dual CPU)
    Symbol Rate
    1-45MBAUD/S
    Flash Memory
    4MByte(8M/16M Optional)
    Code Rate
    1/2, 3/5, 2/3,3/4, 4/5, 5/6, 7/8
    DDR2
    2X512Mbit
    VIDEO DECODE
    Demodulator
    M88DC2800
    Video Decode
    MPEG-2 MP@ML,MP@HL
    MPEG-4 ASP@L5 H.264/AVC, AVS
    VC-1 AP@L3, AP@L2,DivX 3,4,5,6
    TUNER
    Aspect Ratio
    4:3,16:9
    Brand
    Video Resolution
    480p,576p,720p,1080i,1080p
    Type
    Full NIM
    AUDIO DECODE
    Frequency Range
    51~864MHz
    Audio Decode
    MPEG-1/2,layer1/2,MPEG2/4 AAC,AAC+MP3,WMA,Dolby
    Input Impedance
    75***937;
    Sound Mode
    Left/Right/Stereo/Mono
    Input Level Range
    QPSK:-65dBm~-25dBm
    AV OUTPUT
    ANT Loop-Through
    51MHz-864MHz Full Band
    Video Bandwidth
    6.0MHz(-3dB)
    POWER
    Video Impedance
    75***937;
    Input Voltage
    AC 100~240V,50Hz/60Hz
    Video Voltage Level
    1.0 Vp-p
    Consumption
    Max 12W
    Audio Freq. Range
    20~20KHz
    If it isn't broke, don't try fixin it..!!!
    Jun 2011
    Bolton, Lancs.
    or
    OPENBOX C4 Cable Tv
    HD Digital Cable Receiver Openbox C4S
    1.DVB-C
    3.1080P HDMI
    Main function:
    Jun 2011
    Bolton, Lancs.
    Not a right lot cand be found on google, only thing i could find was someone reporting they had it working with cable but it reboots every 5mins, So personally i would avoid it until more info and support can be found, stick with the kryptview and starview... better the devil ya know!
    DK Veteran loncell's Avatar
    Jun 2008
    As a follow up, anyone know if there's anyone doing anything with these boxes firmware wise ? . I got one and its great for keeping the shed door from blowing close.
