Results 1 to 9 of 9
Thread: edc16c34
    Lisbon
    Default edc16c34
    Hi there
    Someone have ori file for edc16c34 psa 75 hp ?
    9653958980
    bosch 0 281 012 620
    I don't have original and don't know what tool was used to get ori file. I'm using the old bdm lad to see if i can return this one to life again.
    Thank you.
    Oct 2011
    more info!!
    what model and car year
    Get push THANKS on right side button . . . . and add
    Jul 2012
    Quote Originally Posted by faiscamix View Post
    Hi there
    9653958980
    bosch 0 281 012 620
    Thank you.
    Your file is not original.
    your file is 75 hp but 110 hp Parther Peugeot 1.6 HDI = 1037377715
    Your file is modified + egr on+dpf off
    Lisbon
    It's a partner 75hp from 2005. These files was what was coming to my hand one suposely original, the others what i got from reading ecu. If you say that it's not original file i believe because this was work of courious. Owner came to me to try to put van to work because the other guy was leaving van completely F%&/ up. Problem is that the car is 500km from me. I really dont's understand this courious guy's, i'm working with this (ecu's) almost every day and i always refuse works that i don't know if i can recover ecu or at least substitute it for a second hand unit. I only accepted this one because by the talk of owner is a sort of a last resort. I don't understand these guy's really i rather to pay for a nice tunned file when i don't know the car and i'm working with cars for years. Well let's see if it will work with a file that i got, if someone have a ori file with eeprom i would thank alot.
    Thank you guy's for support
    Lisbon
    It's working but i would like to make the job perfect. I programmed a dump from a 90hp model, but eeprom still the same so check engine light still on. Someone have both dumps paired for me after to sew them to car ? Thank you again lads
    Lisbon
    Anyone ??? Thank you
    Feb 2011
    You can try this.
    It is from Partner DV6 9HW 2010.
    PierreTheron's Avatar
    Centurion,South Africa
    Seems a new conspiracy happening here .
    we receive non running cars . (Other people maybe stuffed it up by knowing tooooo much on these .. then they run away .Then owner sells on auction as it is going to be too expensive to fix ) Then we end up with it trying to figure out what went wrong on them .. Hmmmmmmmmmmm a good money earner if you know how to get it runner again ...
    So seems some off us must sit on the background waiting for these ..?????
    Lisbon
    Every kid nowadays have interfaces at home and trying to be tunners. How to compete on costs with something like that ? Only way to survive is to have the tools and most important know how to use them right, and wait for this chances to try to pay them. I for many years stoped to make tunning, i will not run the risk for so much litle money. It's harder to fix especialy when we don't know from where they come and what it was made on the car. But i'm glad that i can help and pay the tools along the way. Thank you all for the support
