Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Nov 2010
    Default rate this tune please
    hi anyoane rate this tune please, or maybe have other bether file. tks, cris
    Sep 2009
    Your tunning is skinny and unfinished.
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    Exclamation
    Quote Originally Posted by explorercris View Post
    hi
    this is not chiptuning but this is a cheap tuning,
    you risk to break your turbo with this cheap tuning file
    if you need a proffesionnel chiptuning,send me PM
    Mar 2011
    Bulgaria
    Can someone tell me, is it good this tuning? Thanks
    Sep 2009
    You ask for an opinion and post a password protected file?Is funny...
    Mar 2011
    Bulgaria
    Very sorry about this
    Sep 2009
    Your tunning in not ok.
    Dec 2010
    It makes me laugh when people think they have the skill to detect a good tuned file by eye.
    A perfect tuned file gives perfect AFR for the car in question. Can you see AFR by looking in a file ? No you cannot. You need a datalogger or a dyno to check the quality .
    It saddens me that there are people in this world that tune cars without the right equiptment. If you cannot check your AFR then never assume your work is good.
    Tuning all superbikes all day everyday
    fileservice
    Ninja 250, 300
    Zx10 all till 2013
    Zx14 all till 2013
    Panigale , new mts and hypetstrada
    Hard to solve map projects , ski-doo done
    NEW CBR1000 600 AND VT CRUISER MAPPACKS AND REMAPPING
    Sep 2009
    You're talking nonsense.Good tuned file is a good tuned file and a bad tuned file is bad tuned file.Easy,or want to draw?
    Nov 2012
    Spain
    100 agree with you ducatisti.
  11. #11
    Jun 2010
    But when you look at something and you see that is f***ed up what would you say? I support that someone use winols and learn something day by day, month by month to do his own car. But at the first sight on these I must say that it isn't champion of the world. Diesel runs on everything, but when some pro tuners work with dyno, can count fast in brain airflow/fuel ratio so that it will be enough.
    Some time ago I get to check file from Golf4 after mtm remap, everything documented on 140ps and 360nm but file looked like this from first post...
    Explorercris look for good guides in network, when you will have still troubles, pm me.
    Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
  12. #12
    Sep 2009
    If some say that tuned file are good,its ok,not my problem.Not expect.Test and go to the dyno.
  13. #13
    Jun 2010
    rasequia I got pm from you. Maybe you did not understand me or my language is uncorrect so sorry for my english.
    I wanted to say that it's in my opinion also "cheap tuning" like someone said before.
    I also wanted to say that I saw some files made by pro companies (ex. in my earlier post) when the car doesn't run well, and its visible without dyno, even looking only in maps... I write about these tdi engines of course.
    regards
  14. #14
    drakov's Avatar
    Aug 2008
    Nobody said it was a good file:-), They said it wasn't good, and you don't need any dyno ect to tell that with some remaps, it's the same if you fit brake pads metal side to disc... you don't need a brake tester to tell if they are working 'good'.
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  15. #15
    Sep 2009
    1000 % agree drakov.
