Results 1 to 4 of 4
    Nov 2012
    Default not able to find cccam
    Help
    After a couple of weeks i have found an image that works for my dm800hd pvr clone with sim 201. now running inigma 2010 06 01 experimental .
    but no cccam found in dir.
    have tried loading cccam files in the temp directory.and installing them that doesn't work .
    any ideas on what next
    Jun 2011
    try a different image one that you know works with cccam
    Leeds
    do you mean the cccam on the dm800, press green button, then yellow(addons) then addons download manager within there you will see ccam manager option.....download the cccam file and start cam, after that you should be able to find the cccam files within the directory using FTP client logging on to the box under var/etc should be your cccam files there!!!!!
    hope it helps
    Aug 2010
    Cheers guys
    All sorted. Reloaded image and loaded TSpanel again and downloaded CCam from linux_support_addons and after a reboot it appeared in soft cams.
