Results 1 to 5 of 5
    BAILE ATHA CLIATH
    Default 06 corsa cdl only with ignition on
    hi i have a fault on an 06 corsa the central locking only works with the ignition switched on . it is recieveing a remote signal in the body computer anyone come across this fault ? thanks in advance scoot
    Meat-Head's Avatar
    try rebooting the firmware on that
    BAILE ATHA CLIATH
    Thanks meathead i think its the ignition switch not releasing properly came across it before but couldent remember
    Meat-Head's Avatar
    well then open the door, annoying bellllllllleeeeeepppppp noise
    Ashraf6119's Avatar
    UK
    Make sure when you take out your Ignition Key does the Ignition lock click to switch off the S-Contact..........If not then the system is still seeing the key is in the ignition and it will not lock the vehicle...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
