OCflash Downgrade OPCOM firmware if was upgraded from 2011 2012 official software - Page 4
Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 106
  1. #46
    Aug 2014
    43
  2. The Following User Says Thank You to enteran For This Useful Post:
    metaleks (27th December, 2021)
  3. #47
    Dec 2020
    Nem tudom letolteni
  4. #48
    Dec 2020
    thankyou will download once alloud car
  5. #49
    Dec 2020
    Quote Originally Posted by manocao View Post
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    DOWNLOAD:
    Thanks for Files and Info
  6. #50
    Feb 2021
    Hello, colud someone share with me firmware 1.70 bootloader hex? I need to try change firmware to ver. 1.45 and back to 1.70
    I can not download ver. 1.70 because I do not have permission (probably yet)
  7. #51
    Dec 2014
    PL
    498
    Quote Originally Posted by Tom11 View Post
    Here you go.
    You can do it if you have opcom china clone with real PIC 18F458. (however, you should know that the latest firmware is 1.67 for Opcom 181022a and 200603aEn) FW 1.7 is a Chinese marketing trick. If you have a fake PIC then when you change FW you will kill your cable. Your cable will work on the table but not connected to the car.
  8. The Following User Says Thank You to Mario6 For This Useful Post:
    Tom11 (22nd February, 2021)
  9. #52
    Feb 2021
    Quote Originally Posted by Mario6 View Post
    Here you go.
    Mario6,
    Thank you very much for support.
  10. The Following User Says Thank You to Tom11 For This Useful Post:
    Mario6 (22nd February, 2021)
  11. #53
    Nov 2013
    Hello I flash my opcom but can't get serial and version anymore
  12. #54
    Dec 2014
    PL
    498
    Quote Originally Posted by ttthomas View Post
    Firmware can be changed down or up if your Opcom has a real PIC 18F458. If the PIC is false you will kill the cable.
  13. #55
    Mar 2021
    Hi!
    something like this? "Bootloader did not respond ...either killed interface,empty pic or new protection!"
    is dead now i supposed!
    how can i know if opcom has real pic or not?
  14. #56
    Dec 2014
    PL
    498
    Quote Originally Posted by dbkyriakos View Post
    Hi!
    Read the interface description carefully. Read buyers' opinions, view posted photos. If it is FW 1.99 then it is 100% false PIC.
    1) "OPCOM NEW" PCB without D5 C22 components - can be real PIC
    2) Old Opcom with PCB V5 - if there is no D5, C22 and on the back the date is xx.xx.2007 (not 2013) it can be real.
    1) Type 3 FW 1.7 (i have)
    https://www.aliexpress.com/item/3263...b5a35c0fc2ScNv
    2) V5
    https://www.aliexpress.com/item/3273...74162242.pic_2
  15. #57
    Mar 2021
    This is mine!
    https://imageshack.com/my/images
    I downgrade from 1.99 to 1.39 not working and then 1.41
  16. #58
    Dec 2014
    PL
    498
    This is mine!
    Upload photos of both sides of the PCB here normally. Not by "Images".
    But I think if FW was 1.99 then you killed the cable.
  17. #59
  18. #60
    Dec 2014
    PL
    498
    Just as I thought. Black PCB V6 (2013-6-2) with D5, C22 and fake PIC. Buy another one or repair it if you have the time, possibilities and you like soldering.
