Thanks you. Was trying to find it the whole day
I already posted 1 day ago and can't download anything.
try reading the rules![]()
hello does anyone can help i need opcom sw for firmware 1.39
Here you have the link to Opcom 08.2010 for FW 1.39. (slow download)
But you better read this topic.
https://www.digital-kaos.co.uk/forum...ighlight=opcom
metaleks (27th December, 2021)
Hi i writed fw, flashed correctly after that no interface found when i try to connect what its wrong
Sent from my SM-A125F using Tapatalk
It's normal for Vauxcom 12xxxxx to want to change the FW from 1.39 to 1.45. If you aborted this operation, you probably "cleared" the PIC. Sometimes if it is a real PIC you can load it with OCFlash. If it fails, an external programmer may help.
Upload PCB photos.
(I aborted in first second)I can load fw and write with oc sw correctly but when try to check fw version with opcom sw show only ??? And opcom sw try to update automaticly
Photos of my opcom device and testing modes
I have gqx4 programmer oem made in canada does anyone have any diagram how can connect to write boot area throught bdm mode
Your interface is good quality with Opcom V5 PCB.
Did you let SW Vauxcom 12xxxx finish changing FW to 1.45? If you have not allowed, do it again. Maybe it will help.
I had a similar situation when I wanted to use Opcom 1910xxx Advanced. The software started the FW change but did not complete and cleared the PIC. I couldn't fix it using OCFlash, no FW was visible. I also did not fix it with a programmer. So I bought another one and now I have no problem.
You can find photos of how to connect the programmer to PIC on the Internet. I had an interface with the "Opcom New" PCB.
