Results 106 to 120 of 143
Threaded View
    DK Veteran manocao's Avatar
    Default OCflash Downgrade OPCOM firmware if was upgraded from 2011 2012 official software
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    DOWNLOAD:
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following 81 Users Say Thank You to manocao For This Useful Post:
    707dave (20th June, 2019), aasass (15th January, 2020), adam1w (3rd January, 2019), andreas1996 (18th April, 2021), ANIS2010 (28th November, 2024), apapas (15th November, 2017), bar72 (9th March, 2023), bar7212345 (26th October, 2021), BigJ (24th December, 2018), boobcat (12th December, 2015), cables (20th July, 2019), Col19 (17th November, 2019), Corsa87 (27th October, 2021), Dejfat (4th December, 2018), digitoll (24th December, 2024), djmicos (30th January, 2021), DNatz (23rd July, 2021), donatasslaustas (27th June, 2022), dyc (26th January, 2024), ecufix (6th October, 2019), Faruk6192 (6th April, 2017), frappes (6th April, 2022), gia (9th July, 2021), greywolf1289 (10th February, 2018), Gurbettekises (4th March, 2023), Haed (17th November, 2016), hbalazs (15th November, 2017), jmac200t (16th May, 2020), jokketap (12th July, 2021), junk350505 (30th July, 2019), kamaleon (26th April, 2021), kaziukas1958 (17th December, 2023), KevinXTR (13th April, 2018), kokodrs (20th October, 2023), kral06060 (19th September, 2020), lclassic (5th August, 2022), marcin55246 (23rd August, 2023), marianfratila (6th September, 2024), MarkusP90 (31st December, 2020), martand (8th February, 2024), metaleks (27th December, 2021), micla (7th October, 2015), milerk (10th October, 2013), modiii (25th June, 2022), mtk motors (3rd June, 2022), mylus (30th December, 2017), n599fbm (16th October, 2016), neksus (23rd October, 2021), nikeady (22nd December, 2016), ntentopoulos (21st April, 2021), obeids (21st June, 2019), pablobonome (18th December, 2019), pedritos (25th September, 2017), polete (24th April, 2020), policarpo10 (8th March, 2021), radioman (5th October, 2013), rankan (9th July, 2021), rumensivanov (13th April, 2021), samyy (21st October, 2017), sasdoru (31st March, 2019), SergeyIg (30th January, 2018), Shawnv6 (24th October, 2024), ShineHunter (24th October, 2021), smith007 (28th June, 2020), steffs234 (27th July, 2019), szornyu (26th May, 2018), tomatone (15th June, 2022), Toutancamon (21st April, 2020), tyrantsoft (1st January, 2019), ummagumma64 (7th June, 2022), Youngpopeye (22nd March, 2023)
