Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 143
  1. #121
    Feb 2023
    thanks for this information
  2. #122
    Feb 2023
    I have FW 1.70 how to downgrade it to 1.67 to use 200603a. I have believe i have (checked) real pic there is no C9 and D5 inside.
    What are the steps, do i need to downgrade it firstly to 1.39? Do i need to do something with Restore FDI or not?
    Can someone provide manual step by step what is necessary to do to downgrade to fw 1.67? Also what this means (Attention! OP-COM 200603a only works with original firmware version 1.67. The firmware update to version 1.67 in the OP-COM 200603a program occurs automatically when the program starts.) is it necessary to flash it if i have 1.70 fw i just need to install 200603a with internet and program will install 1.67?
    Sorry and thanks for your support in advance.
  3. #123
    Dec 2014
    PL
    Quote Originally Posted by rzk View Post
    Read here.
    https://www.digital-kaos.co.uk/forum...ighlight=Opcom
  4. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    bar72 (9th March, 2023), kikis (27th February, 2023)
  5. #124
    Mar 2023
    Germany
    Hello Guys
    I have a 1.99 opcom, i somehow managed to flash to version 1.39, then to 1.64.
    But now i get an error message when i try so flash any version (I wanted to flash version 1.67)
    Any ideas on how to fix this, or what went wrong?
    If i have a fake PIC, how did i flash it in the first place?
    Thanks in advance
  6. #125
    Dec 2014
    PL
    Quote Originally Posted by jannik19999 View Post
    Hello Guys
    Thanks in advance
    Hi.
    You can forget about it. You killed your Opcom because it has a fake PIC 18F458. (FW 1.99 always fake PIC that can't be reprogrammed)
    Buy a second one with a real PIC.
    Good luck.
  7. #126
    Aug 2022
    Quote Originally Posted by Rucan View Post
    Here FW 1.33; 1.39; 1.41; 1.43; 1.44; 1.45; 1.59
    Thanks man. I apreciate it.
  8. The Following User Says Thank You to ari01 For This Useful Post:
    jo2023 (25th July, 2023)
  9. #127
    Aug 2023
    Thanks for firmware
  10. #128
    Apr 2016
    please don't forget to say thank you.
  11. The Following 4 Users Say Thank You to lucas39 For This Useful Post:
    DennisD123 (7th May, 2024), hamouess (16th April, 2024), Pasta19881 (28th June, 2024), selwyn001 (10th October, 2023)
  12. #129
    Aug 2018
    United Kingdom
    Which firmware version have you found to work best with Astra H?
  13. #130
    Oct 2023
    NL
    Quote Originally Posted by manocao View Post
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    DOWNLOAD:
    Oh, why I always logged out when I try to download that OCFlash.zip file? can anyone help please?
    Thanks a lot
  14. #131
    Oct 2023
    NL
    Thank you very much for sharing your result, I really hope that every one tried to downgrade any china clone version 1.xx to 1.39 to share his experience and results.
    @zwkrz many thanks to you.
  15. #132
    hello, what opcom firmware i will need for OP-COM_200603a for mine 2018 car please? i have installed software but when i go to test interface nothing happening, im currently on 1.45 and will not install automaticaly.
  16. #133
    Jan 2024
    Hi fellas. Sorry to refloat this. I've recently bought an OPCOM for my girl's Corsa C. I want to make some keys. I've one of those v1.70 that I'm willing to downgrade. I've downloaded 090714 but EPROM button is not shown. I've not downgraded firmware yet, but i think software should be showing it, doesn't it?
  17. #134
    Jan 2024
    can any one help me to find fw1.99
  18. #135
    Jan 2024
    FYI I recently bought one of those "v1.70" and I think I won the lottery. I've used it with Fantomel 200603 and it read the security code without downgrading it. I've already made 2 more fob keys and lurked around the bcm blocks like a child in a toy store
