Page 6 of 9 FirstFirst 123456789 LastLast
Results 76 to 90 of 135
  1. #76
    Feb 2020
    Sorry for bump but well
  2. #77
    Jul 2021
    Thanks you. Was trying to find it the whole day
  3. #78
    Jul 2021
    I already posted 1 day ago and can't download anything.
  4. #79
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    try reading the rules
    Aug 2021
    Quote Originally Posted by manocao View Post
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    DOWNLOAD:
    Thanks, i need to do this to get the security code, so soon as i can dowload it, i will try
  6. #81
    ASCM's Avatar
    Oct 2018
    hello does anyone can help i need opcom sw for firmware 1.39
  7. #82
    Dec 2014
    PL
    Quote Originally Posted by ASCM View Post
    Here you have the link to Opcom 08.2010 for FW 1.39. (slow download)
    But you better read this topic.
    https://www.digital-kaos.co.uk/forum...ighlight=opcom
  8. The Following 3 Users Say Thank You to Mario6 For This Useful Post:
    bar72 (9th March, 2023), kokodrs (20th October, 2023), metaleks (27th December, 2021)
  9. #83
    ASCM's Avatar
    Oct 2018
    Hi i writed fw, flashed correctly after that no interface found when i try to connect what its wrong
    Sent from my SM-A125F using Tapatalk
  10. #84
    Dec 2014
    PL
    Hi.
    One question. Does your Opcom interface have a real PIC 18F458 or have you done a firmware upgrade before?
    If there is no real PIC 18F458 then by changing FW you killed the interface.
    What firmware did you have before?
  11. #85
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by Mario6 View Post
    Hi.
    I have not opened the opcom HW to check which mcu it have but ori firmware was 1.39 but when i used a different sw vauxcom sw it tried to update the tool after that begin problem
  12. #86
    Dec 2014
    PL
    It's normal for Vauxcom 12xxxxx to want to change the FW from 1.39 to 1.45. If you aborted this operation, you probably "cleared" the PIC. Sometimes if it is a real PIC you can load it with OCFlash. If it fails, an external programmer may help.
    Upload PCB photos.
  13. #87
    ASCM's Avatar
    Oct 2018
    (I aborted in first second)I can load fw and write with oc sw correctly but when try to check fw version with opcom sw show only ??? And opcom sw try to update automaticly
  14. #88
    ASCM's Avatar
    Oct 2018
    Default OCflash Downgrade OPCOM firmware if was upgraded from 2011 2012 official software
    Photos of my opcom device and testing modes
  15. #89
    ASCM's Avatar
    Oct 2018
    I have gqx4 programmer oem made in canada does anyone have any diagram how can connect to write boot area throught bdm mode
  16. #90
    Dec 2014
    PL
    Your interface is good quality with Opcom V5 PCB.
    Did you let SW Vauxcom 12xxxx finish changing FW to 1.45? If you have not allowed, do it again. Maybe it will help.
    I had a similar situation when I wanted to use Opcom 1910xxx Advanced. The software started the FW change but did not complete and cleared the PIC. I couldn't fix it using OCFlash, no FW was visible. I also did not fix it with a programmer. So I bought another one and now I have no problem.
    You can find photos of how to connect the programmer to PIC on the Internet. I had an interface with the "Opcom New" PCB.
