Page 7 of 9 FirstFirst ... 23456789 LastLast
Results 91 to 105 of 135
  1. #91
    Rider667's Avatar
    Feb 2020
    my MC saddle
  2. The Following User Says Thank You to Rider667 For This Useful Post:
    Mario6 (13th October, 2021)
  3. #92
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by Mario6 View Post
    Your interface is good quality with Opcom V5 PCB.
    Did you let SW Vauxcom 12xxxx finish changing FW to 1.45? If you have not allowed, do it again. Maybe it will help.
    I had a similar situation when I wanted to use Opcom 1910xxx Advanced. The software started the FW change but did not complete and cleared the PIC. I couldn't fix it using OCFlash, no FW was visible. I also did not fix it with a programmer. So I bought another one and now I have no problem.
    You can find photos of how to connect the programmer to PIC on the Internet. I had an interface with the "Opcom New" PCB.
    No i dont let to finish upgrade fw ,do you have a good vauxcom 12xxx to try?i can flash ok with oc sw i can write any firmware its not a problem, but why device does not change status in HW port in pc to "opcom device"
    Sent from my SM-A125F using Tapatalk
  4. #93
    Dec 2014
    PL
    After one use, Vauxcom changes VID and PID and name to "USB Serial Coverter". The VID remains the same but the PID 6001. In the device manager, check your VID and PID. Previously, the name was "Opcom V2" - VID 0403 PID 4F50.
    To revert to the previous name you would have to use MPROG 3.0 and upload the previous EPT (VID 0403 PID 4F50).
    However, any newer SW Vauxcom or Opcom will rename you to "USB Serial Converter" and automatically load the higher FW 1.45, 1.64, 1.66, 1.67.
    Is your Opcom still working and able to connect to the car?
  5. #94
    ASCM's Avatar
    Oct 2018
    No i cant connect with car when trie to connect with device or car ,opcom log show" problem com with device"
  6. #95
    ASCM's Avatar
    Oct 2018
    Solved thankyou very much, i have the same situation with vcds i bought before 2 months
    A maked a mistake tried to upgrade sw to a higher level online to the vcds server and its blocked(i bought on aliexpres ) does anyone can help me how can i repair firmware of vcds cable ?
  7. #96
    Dec 2014
    PL
    Quote Originally Posted by ASCM View Post
    If you have an VCD$ interface with an ATMEGA 162 chip, use the KOLIMER 9.2 loader.
    https://www.digital-kaos.co.uk/forum...light=vag+vcds
  8. #97
    ASCM's Avatar
    Oct 2018
    Im opening it to check which mcu have
  9. #98
    ASCM's Avatar
    Oct 2018
    Here the photos/ATMEL atmega 162/
  10. #99
    Oct 2021
    is it worth downgrading from 1.99v to 1.64v ?
  11. #100
    Dec 2014
    PL
    Quote Originally Posted by argotrix View Post
    I don't want to worry you but if the original firmware is 1.99 then 99.0% you have a fake PIC 18F458. If you change FW to other (1.64) you will kill your interface. Unscrew the cable and see if the PCB has elements D5, C22 and the date 2013.6.2.(Fake)
  12. #101
    Oct 2021
    thanks for ocflash
  13. #102
    Oct 2021
    hello,i can t not download ocflash,please help my !thanks!
  14. #103
    Rider667's Avatar
    Feb 2020
    my MC saddle
    maybe this help
  15. The Following User Says Thank You to Rider667 For This Useful Post:
    ecufix (22nd November, 2023)
  16. #104
    Nov 2021
    Hi. I'm trying to download but i cant. Is it possible to share another link for everyone .)
    Chinese OP COM works with OP COM CHINA 082010 and fake VauxCom 2012, 2014 and 2016. To work with Opcom 082010 you need FW 1.39 and for Vauxcom 1.45. The latest original FW is 1.66. The rest 1.70, 1.95, 1 ..... are Chinese marketing tricks. But if you really need 1.70 then you have it here.
  17. #105
    Dec 2021
    Post OpCom Firmware
    Hi, I couldn't download your old firmware upload. Could you send FW v1.70 please and 1.95 and 1.99 if you have them.
    Thank you in advance.
