Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 135
Hybrid View
    DK Veteran manocao's Avatar
    Sep 2009
    Default OCflash Downgrade OPCOM firmware if was upgraded from 2011 2012 official software
    i found a program that is supposed to be able to downgrade opcom firmware to 1.39 EVEN if it was upgraded to 1.41 or 1.43 or 1.44 or 1.45 by means of 2011 2012 official opcom software
    no matter if you started some 2011 2012 official opcom version with interface plugged in computer, which would have upgraded to 1.43 or 1.44 but disabling bootloader
    2011 and 2012 official software versions of opcom dont erase pic of interface but disable bootloader
    ocflash doesnt work if you started some 2010 version with interface plugged in computer, which erased your interface's pic
    howto:
    1. connect opcom interface through usb only
    2. run ocflash
    3. click on "request interface" to check actual version programmed on interface
    4. if programmed version is 1.44 or 1.45 click "load firmware" and select fw139.hex from "Firmwarefiles" folder
    5. click "change"
    6. select "automatic mode" and click "flash"
    DOWNLOAD:
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following 76 Users Say Thank You to manocao For This Useful Post:
    707dave (20th June, 2019), aasass (15th January, 2020), adam1w (3rd January, 2019), andreas1996 (18th April, 2021), apapas (15th November, 2017), bar72 (9th March, 2023), bar7212345 (26th October, 2021), BigJ (24th December, 2018), boobcat (12th December, 2015), cables (20th July, 2019), Col19 (17th November, 2019), Corsa87 (27th October, 2021), Dejfat (4th December, 2018), djmicos (30th January, 2021), DNatz (23rd July, 2021), donatasslaustas (27th June, 2022), dyc (26th January, 2024), ecufix (6th October, 2019), Faruk6192 (6th April, 2017), frappes (6th April, 2022), gia (9th July, 2021), greywolf1289 (10th February, 2018), Gurbettekises (Yesterday), Haed (17th November, 2016), hbalazs (15th November, 2017), jmac200t (16th May, 2020), jokketap (12th July, 2021), junk350505 (30th July, 2019), kamaleon (26th April, 2021), kaziukas1958 (17th December, 2023), KevinXTR (13th April, 2018), kokodrs (24th October, 2023), kral06060 (19th September, 2020), lclassic (5th August, 2022), marcin55246 (23rd August, 2023), MarkusP90 (31st December, 2020), martand (8th February, 2024), metaleks (27th December, 2021), micla (7th October, 2015), milerk (10th October, 2013), modiii (25th June, 2022), mtk motors (3rd June, 2022), mylus (30th December, 2017), n599fbm (16th October, 2016), neksus (23rd October, 2021), nikeady (22nd December, 2016), ntentopoulos (21st April, 2021), obeids (21st June, 2019), pablobonome (18th December, 2019), pedritos (25th September, 2017), polete (24th April, 2020), policarpo10 (8th March, 2021), radioman (5th October, 2013), rankan (9th July, 2021), rumensivanov (13th April, 2021), samyy (21st October, 2017), sasdoru (31st March, 2019), SergeyIg (30th January, 2018), ShineHunter (24th October, 2021), smith007 (28th June, 2020), steffs234 (27th July, 2019), szornyu (26th May, 2018), tomatone (15th June, 2022), Toutancamon (21st April, 2020), tyrantsoft (1st January, 2019), ummagumma64 (7th June, 2022), Youngpopeye (22nd March, 2023)
  3. #2
    Member ogo777's Avatar
    Nov 2009
    croatia, zagreb
    hello mr.manocao
    you are big, best wizard
    which version op com you have for diagnostic
    can you post it here
    cheers
    Sep 2009
    i still use 100219a (08/2010)
    __________________
    Jul 2017
    Very usefull information..
    I have version 1.45 I want to downgrade, do you know where i can find firmware 1.39 ?
    Thanks in advance
  6. #5
    Nov 2017
    I have version 1.70 and I want to downgrade to 1.39. Is that possible?
    Thank you
  7. The Following User Says Thank You to apapas For This Useful Post:
    integrala86 (2nd December, 2017)
  8. #6
    Dec 2017
    Quote Originally Posted by apapas View Post
    Thank you
    please tell here if you can do that
  9. #7
    Sep 2009
    why don't you just download and try!!
    ocflash will downgrade 1.xx to 1.39 (included firmware) except if interface's pic was erased
    __________________
  10. #8
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all,
    I have this fw v1.64, enjoy....
    Regards, G
  11. The Following 20 Users Say Thank You to gopelhu For This Useful Post:
    707dave (20th June, 2019), Adi202 (3rd April, 2023), bilgehan (12th October, 2019), Col19 (17th November, 2019), dmerkovic (25th July, 2019), dobo2 (7th April, 2024), kokodrs (20th October, 2023), LRobert (8th October, 2020), metaleks (27th December, 2021), mtk motors (3rd June, 2022), no1baggiesfan (25th May, 2021), polete (24th April, 2020), racin-snake (3rd January, 2018), rzk (24th February, 2023), sergei5005 (8th October, 2019), Toldy (4th March, 2019), tomxx (28th July, 2019), ummagumma64 (7th June, 2022), yysnet (29th October, 2019)
  12. #9
    Aug 2018
    Germany
    Default OP-COM FW
    Here FW 1.33; 1.39; 1.41; 1.43; 1.44; 1.45; 1.59
  13. The Following 28 Users Say Thank You to Rucan For This Useful Post:
    1971 (23rd March, 2023), 707dave (20th June, 2019), Adi202 (3rd April, 2023), Adiadi (11th August, 2020), ari01 (30th May, 2023), Ashraf786 (7th February, 2023), bar72 (9th March, 2023), cables (20th July, 2019), Col19 (17th November, 2019), craetos (22nd January, 2023), djmicos (30th January, 2021), Gurbettekises (25th September, 2023), kodiran (16th April, 2021), laurentiudania (2nd June, 2022), martand (8th February, 2024), metaleks (27th December, 2021), milosmaka (3rd January, 2024), obeids (21st June, 2019), polete (24th April, 2020), pretto07 (3rd May, 2021), rzk (24th February, 2023), sarigol45 (28th June, 2022), steffs234 (19th July, 2019), tomxx (9th November, 2018), ummagumma64 (7th June, 2022), ylie86 (31st May, 2023)
  14. #10
    Sep 2018
    Thank you for those useful information.
    Rucan, I cannot download the attached file "Firmwarefiles.rar" (I can only download OCFlash on the first message), could you provide a download link please ?
    Thank you by advance .
  15. #11
    Jun 2019
    I hope this solves my problem
  16. #12
    Jul 2019
    Hello every one!
    I would like download 2 files (OCFlash.zip, Firmwarefiles.rar FW 1.33; 1.39; 1.41; 1.43; 1.44; 1.45; 1.59 but I cannot.
    Would send those me by mail? xxxxxxxxxxxxxxx
    Thank you for your help!
    Last edited by Tom6609; 20th July, 2019 at 08:08 PM. Reason: no addys read the rules !!!
  17. #13
    Aug 2019
    UK
    Hello everyone,
    I am new on here and looking to get some help on my OP-com device. I just have purchased a device where the firmware version is V1.70 (able to be upgraded and downgraded) and needing some help as I have flashed to V1.59 but now wish to flash it back to V1.70.
    Since at the "Firmwarefiles" folder the higher version is 1.59, how can I get the 1.70 version back on my device ?
    Any help would be much appreciated
  18. The Following User Says Thank You to XtRYaM5Pt For This Useful Post:
    ltaylor (5th May, 2021)
  19. #14
    Jun 2020
    Hi Is OCFlash available as a download on the internet,as I am not able to download the zip file posted by Manocao?
  20. #15
    Member vanders's Avatar
    Nov 2018
    Costa Blanca - Spain
    Its all in : opcom FW V 1.64. rar
