Results 1 to 9 of 9
    Mar 2012
    Default MB C220 NO START
    Have a Merc c220 cdi 03 plate , when key inserted steering lock released and ignition will turn on, BUT no crank & no start some electrician was checking for some fault in tail lamps after his testing car no start & no crank i have attached ECM photos
    workshop
    w203 .check fuse and startrelay on front sam
    Feb 2011
    60N 25E
    if fuse and relay is ok,
    try hit start seim time when turn key start position
    (meny time when cdi start go brouk this help litel time)
    Oct 2012
    check fuse 15A front sam!
    Dec 2011
    change the front sam
    Autotecno2006's Avatar
    Hi, usually fuse or starter relay, if not do diag with starr, no point spending cash on parts till u know what exactly problem is. Regards P.
    Mar 2012
    checked all fuses & sam units by another car all working good only ecm esl & key module putting to another car car no start
    Mar 2012
    can i post the data of ecm
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by DOCKERS View Post
    Chech Can connections inside car next to front door pilar.
