FG tech read/ write ok
have done it EDC17CP20/14
bootmote trice pass
try agian
bootmote trice pass
try agian
Have I asked about EDC17CP20/14? At the moment I am not interested in this unit, I am interested EDC17C54-3.39 VW Crafter CKTB 2.0L.FG tech read/ write ok
I try last week to read this ecu, but inside there is a new antituning type. I close the ecu. The boot is ok! Bye
Yes, I'm talking about it. But I have no right to say "Goodbye!" - I have to find a solution.inside there is a new antituning type
hi new Genius works fine on c54 and probably other pro tool
Genius regarding information 100%? Please give a link where to buy Genius. What other options? This ECU is declared in MagPro , but I have no information on how it works.
I have new genius and new trasdata, all from dimsport, but at the moment we can't work on this ecu.
CP54 doesn't work in Galletto2... seed keys are wrong..
From clones - K-Tag..
Official - CMD
I tried K-TAG official. Does not work.From clones - K-Tag..
I can calculate the seed_key by serial number Tricor.
How can I feed seed_key ECU?
446px-VAG_EDC_17C54_1797_Int_CAN.jpg800px-VAG_EDC17.jpgHi, this is for kess v2 on tricore mode. maybe helps.
I've read many of these even with Ktag clone Make sure you use correct protocol and that have good bootpin connection. If you need some help, write me PM.
Hi, I pulled out this thread because of some differences writing this crafter ecu by OBD with fox. The write job was done fine, also the chk fox made, car starts after I wrote the file .... but ... I made a test - readout after the dump was written to ecu and compared it with dump i wrote to it. Not all changes made are in the test-readout , how could that be ???
