407 HDI 1.6 DPF OFF 2006MY - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Jul 2012
    5
    Downloads
    Uploads
    Default fap off!!
    I think that the files that you have tried are not good if you want to test my
  2. #17
    Downloads
    Uploads
    Mario38
    I wrote your file
    Recoded injectors and configuration for engine ecu
    cleared faults
    Went to BSI config and changed fuel to diesel without filter as I missed this before. cecked cust options petrol or diesel engine without filter. checked ecus present no additive ecu.
    started fine no errors turned off found only errors as before
    took for test drive ok for 10 minutes then depollution system faulty.
    read codes now has additional code for turbo pressure to high. Would this cause the depollution error also?
    J5
  3. #18
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    19
    Downloads
    4
    Uploads
    last week,i have donne chiptuning foe 207 1.6hdi from 110cv to 150cv with succes,cleint was very very happy
    do you want to see your car fly johny?
  4. #19
    Jul 2012
    5
    Downloads
    Uploads
    Quote Originally Posted by Johnnyrb5 View Post
    Mario38
    I wrote your file
    cleared faults
    J5
    this is strange I have other cars and 100% ok .. maybe your problem is writing file .. I advise you to bdm use
    if you remember a thank you about the same
  5. #20
    Downloads
    Uploads
    Hi Mario,
    yes I thought also I am using Galeto cable and software called "New Serial 1260" to write/read file.
    Can you advise how to get BDM?
    J5
  6. #21
    Nov 2012
    smartville in front of a OBDplug
    35
    Downloads
    10
    Uploads
    Hi Mario,
    J5
    your tool not read and recode the injectors ....
    best is do it bdm if you have no good obd tool
    i do them cmdflash never injector code lost ...
