Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    Default 407 HDI 1.6 DPF OFF 2006MY
    Hi Everybody,
    Can someone please help me remove DPF from this ECU manually.
    I have tried incorrectly with ECUSAFE and all looked fine but car will not rev above 3000rpm no DTC in pp2000.
    Many Thanks
    J5
    PS I removed dpf in pp2000 cust options and changed additive ECU to absent
    DK Veteran ZIZZOU's Avatar
    Dec 2011
    try this and report
    Thank you zizzou will; try later today.
    Is this a manual edit?
    mbtun's Avatar
    May 2012
    Europe
    should be single switch solution.
    hey G you still around? I though you are not around anymore?
    Dec 2011
    let's tray,and repport for result johny
    Hi I wrote file and Engine ECU lost configuration and I have lost all injector codings.
    I have added the settings best I can but some I am not sure of especially gearbox type and alternator class and body configuration can someone advise? I have to enter the codes for the injectors. Is cylinder 1 near the timing belt or the gearbox on this car? There also errors relating to FAP still. Car starts but only revs to 3000 rpm and dispalys engine management system faulty.
    Pleaase help
    J5
    Additional photo
    Top Poster + yas200's Avatar
    Jun 2012
    Estonia
    Quote Originally Posted by Johnnyrb5 View Post
    Additional photo
    Send #dtc. I can help you. No need sensor
    CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
    Dec 2011
    hi
    first,recode injectors,Ist cylinder 1 near the gearbox
    mbtun's Avatar
    May 2012
    Europe
    mr G brings bad luck )
  11. #11
    barti122's Avatar
    Nov 2009
    Poland N
    what is the number for the ecu
    Sorry for my English.
    GG 5268481
    We are here to help each other unselfishly
  12. #12
    barti122's Avatar
    Nov 2009
    Poland N
    try this files first chec 407 1.6 fap off cheksum moj
    GG 5268481
  13. #13
    mbtun's Avatar
    May 2012
    Europe
    your file won't do any good. he lost car configuration and car must be recoded.
  14. #14
    Dec 2011
    in 1.6HDI engine,i recode injectors in 10 minutes
  15. #15
    Thank you for your help.
    Recoded injectors car running normally now
    Car only has these errors. I told ecu I had topped up the additive level & replaced DPF, Can I remove connection to tank or just ignore as all seems fine now?
    Engine ECU
    Additive system Value received by CAN Incorrect
    Additive system Quantity of additive to high
    Additive system Fuel tank cap sensor
    Additive system * Critical level of additive in the resovoir
