Results 1 to 9 of 9
    Jul 2008
    Default Losing Brake Fluid??
    Over the past month or so my car handbrake light has come on intermittently when driving. Thought initially that i just needed to top up the brake fluid. Sure enough this fixed it but light just came on again today. Noticed a relatively small damp patch on the ground at the rear wheel (drivers side) of the car. Anyone any ideas what this could be.
    I know absolutely zero about cars and will take it to a garage but a "heads up" would be appreciated. Big job or not?
    thanks in advance.
    Feb 2009
    Default brake fluid
    could be one of the seals gone on your rear brake cylinder, get down to floor level and see if the back of the rear hub is wet.
    Handrake warning lights tend to be switches connected to the handrake handle rather than connected to the brakes themselves. Phone your local dealer ask for the service centre and explain they will tell you
    Mar 2008
    Coatbridge
    Get it checked ASAP mate, you don't want your brakes failing.
    gmb45
    Guest
    Quote Originally Posted by bugaloo41 View Post
    thanks in advance.
    definitely brake cylinder m8 had exactly the same thing happen to my car,and my brakes went, so get it fixed before your in a fix.also dont try and save money by just having one side done, or u may find the other may go to
    Jul 2008
    Cheers for the help guys much appreciated.
    Sep 2008
    u could have said what box u have and have u updated it and yes things can be fatal
    Mar 2008
    Coatbridge
    Quote Originally Posted by gmb45 View Post
    Absolutely, do both at the same time.
    If one has went then the other is sure to go soon.
    Member Shortie's Avatar
    Feb 2009
    If brake fluid is leaking onto the ground from the rear hub/back plate, then you can be sure it has got onto the brake shoes, in which case you will need to change the shoes on both sides as well.
    Sep 2008
    as said car was never mentioned,it might have brake pads fitted to rear,also might have hydraulic clutch,they leak as well,brake pipes rot in uk due to salting of roads in winter,also rubber pipes can leak.have it properly looked at.
