hi can u help me to change km the original have 208572 i want 138000
its motorola 11e9
its motorola 11e9
scoot (3rd April, 2018)
faki (28th March, 2014)
i have the same problem can someone help me,dash board from ford focus 2001,but i dont know what ITS must read.I have X-prog and Carprog 4,74
Ok.i dont have nyo software.Thanks.i will try to find nyo.
I have N760006CFKC322
99-c170 hec,i read is the same with MC68HC11E9
what procedure i can use,i have X-prog,and i must desolder PLCC52,can i reprogram in circuit without desolder.
Without desolder, x-prog is better for this hc11.
you should connect:
2+3 together
17 reset
20 rx
21 tx
GND - pin 1 and +12V pins 14+16
then read caclulate and program
regards
kennedy-afn (4th March, 2015)
i have soldered wires from adapter hc11e9
to dash board and i have eroor no
comunication
you are shore 14+16 to +12V?
http://html.alldatasheet.com/html-pd...C68HC11E9.html
PC5/addr/data pin14
PC7/addr/data pin16
attempt ...you can take off crystal with dash boards...
problem solved,i desolder its , must select in X-prog MC68HC11E9(wsecurity0F36W),with 4E28B not working
things4u2get (18th January, 2023)
always is better to desolder if you have adapter..is more safe than solder wire on pins.
FILE SERVICE
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agricultureGenuine WinOLS user
