Results 1 to 15 of 20
    klonone's Avatar
    Default how to programm transponder key ISUZU TROOPER
    Hi I need to activate the transponder keys of a 1998 Isuzu Trooper 3.0 d
    by mistake I deleted the keys ecu
    I have the pin code to do so
    I tried to activate the keys to the programmer t300 Chinese but always says incorrect code
    please how I can change the keys?
    this dump for immo box ,mi code is 1697 correct??
  2. The Following 2 Users Say Thank You to klonone For This Useful Post:
    missfixit (4th January, 2014), rafal (30th April, 2021)
  3. #2
    keygargoil's Avatar
    no your pin is 9716 and there are 2 keys programmed because you never completed programming it didnt erase the keys
    klonone's Avatar
    Default help
    then my problem is that I married the engine ecu with immo
    that the check engine light is blinking always
    since his diagnosis with machine engine parameters within mistakenly delete keys
    please help
    Nov 2012
    tech2 for isuzu the 10 meg card should cover it.
    rdu04's Avatar
    RO
    a question please what tip transponder need id48 or 4d60?
    4D60 FROM 1999
    topclef's Avatar
    Isuzu trooper 1999 need transponders tiris DST4E ( ID64 )
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
    rdu04's Avatar
    RO
    this immo car 2000 year isuzu trooper 3.0
    someone knows exactly what type of transponder
    eprom 93lc66
  10. #9
    rdu04's Avatar
    RO
    I'll try with id 64 and 4d60 and communicate results
  11. #10
    rdu04's Avatar
    RO
    Opel, Isuzu immobox Tokai-Rika with ID4D-64
    Memory device is serial eeprom 93c66 DIL8 package.
    Expected file size is 512 bytes.
    Use JMA TPX2 - Errebi TX2 transponder.
    Written transponder is ready programmed to start car.
    Vehicles equipped with this unit:
    Opel: Monterey
    Isuzu: Big Horn, Trooper
    it looks like you're right topclef
  12. #11
    topclef allways right!!!
  13. #12
    rdu04's Avatar
    RO
    I do not mind totalkey information found in the modules to tmpro but I have not programmed key will return the information
  14. #13
    rdu04's Avatar
    RO
    I programmed key id 4d-64
  15. #14
    Dec 2010
    please pin code for this dump
    isuzu 1998 trooper 3.0d isuzu 897168413 tokai rika co.,ltd 93lc66
  16. #15
    dyzio's Avatar
    Jan 2014
    Racek
    your pin 3246
  17. The Following User Says Thank You to dyzio For This Useful Post:
    xteam (25th February, 2014)
