Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Nov 2009
    Poland Rzeszow
    Default VP44 IDS Procedure programming
    Hello,
    I search procedure programing for VP44, maybe someone have ?
    Thanks in advance.
    Sorry for my english, I'm learning everyday.
    I'm not sharing passwords, write your thread, and send me link on PM. If I can help. Let me help.
    Dec 2009
    i think that is possible only in service centre
    3in1san's Avatar
    Nov 2009
    in the middle of europe
    You need IDS ford.
    May 2009
    and which is Procedure programming ???????
    DK Veteran zoro1's Avatar
    May 2010
    Bulgaria,Sofia,Vidin
    What do you whant to do?put secon hand pump in car?
    there is option in menu ,mast find outcode,then calculate incode and write with IDS in pump/all thi tru obd/
    if you hawe a brand new pump with module -only bosch 815 can program pump ecu/psg5 /.The psg5 is OTP.
    Large nations behave like gangsters ,and young as prostitutes !
    Nov 2009
    Poland Rzeszow
    Car is Ford Transit 2001, and I need only change the ECU from VP44.
    I have used ECU from another car. I also have IDS Ford. I want to know if I can add a used ECU to another car. I also have a calculator INCODE-OUTCODE
    May 2010
    No need for incode on 2001 model & yes you can use used parts.
    Jan 2010
    if you have Bosh KTS it's easy and don't need in code
    May 2009
    kts works ok in this pumps
    regards
    Aug 2011
    Default ids
    hello, you must to select car- --module programing--security---select PCM--- match new module-select new FIP.
  11. The Following User Says Thank You to ciptel07 For This Useful Post:
    Pzolee (7th June, 2013)
  12. #11
    May 2010
    The ECU mast be from the same car!I mean engine the same and main ECU the same brand and model!You can not put ECM from 1.9L engine to 2.0L engine .
  13. #12
    Jun 2009
    pleas name of cable or refrance used with kts
    Quote Originally Posted by cezarycezary8 View Post
  14. #13
    May 2010
    Make it your own!Conect K-lines ,CAN lines and power,two cables for power and you are rich with 200 EURO....And bosch poor -200Euro.
  15. #14
    Jun 2009
    can you give pinout pleas
  16. #15
    May 2010
    for PSG 5 ,for OBD 2 see link.
    http://www.obdstore.com/wp-content/u...ble_pinout.png
  17. The Following User Says Thank You to zoro1 For This Useful Post:
    mexanico1971 (18th February, 2017)
