Results 1 to 3 of 3
    DK Veteran tapiru's Avatar
    Default DAS 01.2012 error after SDconnect settings
    Hello guru's
    I helped a friend to install 01.2012 DAS-Xentry and all went good without any problem.
    Finally was need to play little with SDnetControl so to have internet access having just a C3 mux.After this action I get this error who was not before the SDnet settings.
    Mention it was applied already cal870 fix and after error to pop up again applied,but still error exist.Did I'm do a mistake somewhere or what? how to solve this problem?
    Thanks in advance
    So you did not try the SW before applying the CAL870 fix? Which fix did you apply, there are many of those and not all are good.
    I was able to test it just in SIM mode and so all went good with cal870 and cal872 fix already applied.This error came out just after SDconnect setup .
