Results 1 to 15 of 15
    Feb 2010
    Default xprog repair i need tested file ,atmel64 and other
    hi i have problem whith x-prog i need tested files of atmega and the other if is necesary too whith sw please for v 5.0 , i have this problem when i push update say to me "device is silent" usb works i think , the sw conect when i enter de wire of the usb and to change the undefinide to usb com port 3 ,i try many dump for atmel but i dont khow if necesary to put the 93c46 too and dont works anyfile,
  2. The Following User Says Thank You to javilette For This Useful Post:
    shtyrya2 (28th October, 2013)
  3. #2
    adam28's Avatar
    May 2009
    UK Essex
    Hi mate
    Did you solve your problem? did you try to write 93C46.
    Cheers
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
    Jun 2009
    use a pc with a good supply in current in usb .
    unistall the driver and install it again .
    if not works use a old version of xprog softawe and make update.
    Feb 2010
    no i dont solve the problem tomorow i recived one xprog of my friens i will read the atmel flash and eprom and 93c46 and and try i have 3 x prog whith this problem , i have to repair can you help me adam28
  6. #5
    Oct 2012
    Hello
    This is what you need him
  7. #6
    adam28's Avatar
    May 2009
    UK Essex
    Did you erase atmega64 before you programmed?
  8. #7
    adam28's Avatar
    May 2009
    UK Essex
    Load Flash, Eeprom and cfg into your xprog5.0 software which is inside a folder in the rar
    Have +12 in socket of xprog you are programming like in picture.
    Do not read Atmega just Erase it. If you do read just reload the project.
    Then write project to your Atmega64
    Works for me everytime.
    No need program 94c46
  9. The Following User Says Thank You to adam28 For This Useful Post:
    pbn (21st September, 2013)
  10. #8
    Feb 2010
    i write whith upa because i dont eraser but i write and verifiquy ok ,can be this the problem , i think the files is worng the flash and the eprom of atmega the xprog i have broken i can try wihth the x prog of my friens i recived today. is this for version 5 , thank you i post result
  11. #9
    adam28's Avatar
    May 2009
    UK Essex
    use xprog to xprog for programming. These files work everytime for me with full Auth. You need to erase first.
    Follow instructions with your friends xprog. I dont use UPA for this project.
    Yes with ver5.0 Use quality USB cable, not china sh!t which is about 3 miles long
  12. #10
    adam28's Avatar
    May 2009
    UK Essex
    Quote Originally Posted by javilette View Post
    All ok now mate?
  13. #11
    Jan 2010
    Germany
    Sometime this problem can be in Atmega64(can be damaged some ports). It will flashing, verified - but dont work. Try to change Atmega.
  14. #12
    smayer's Avatar
    Jan 2012
    Tested files for xprog
  15. The Following User Says Thank You to smayer For This Useful Post:
  16. #13
    adam28's Avatar
    May 2009
    UK Essex
    Already posted tested files mate,and if they dont work he has other problem.
  17. #14
    Feb 2010
    hi adams i have problem whith your projects i can write the files of smayer but dont works when i put your project i can eraser the atmel but when i pust to write i have this.
  18. #15
    adam28's Avatar
    May 2009
    UK Essex
    It wont find path as the path is my desktop
    just load manually
    Here
    rar in post7 edited. Added more info
  19. The Following 2 Users Say Thank You to adam28 For This Useful Post:
    pbn (21st September, 2013), shtyrya2 (28th October, 2013)
