Results 1 to 5 of 5
    Junior Member Del_RFC's Avatar
    Nov 2008
    Default Openbox S10 Continually Dropping CCCam Connection
    I have a Openbox S10 which is giving me some grief.
    It will connect in to the router via homeplugs network then run for 10 mins then drop the connection. I then need to reboot the box or restart the homeplug and it kicks in again.
    Suspecting they were the problem I bought a new set of homeplugs and exactly the same thing is happening.
    To confirm it is defo the box I have another S10 which I swapped over now running flawlessly on the same connection.
    The cccam section shows as KO'd :-( when the connection drops. A quick reboot and we are back in business.
    Both boxes are running on the same firmware.
    Any ideas guys?
    DK Veteran hooley's Avatar
    Jul 2009
    Galway Ireland
    have you same firmware on both?
    Nov 2008
    Quote Originally Posted by hooley View Post
    Yes, what I think I will do is copy the version from the working box to the dodgy one and see how I get on.
    DK Veteran ajax2061's Avatar
    Nov 2012
    worcestershire
    tried it without the homeplugs ? they only as good as your rmains wiring after all
    I would try it with a long network cable or move it close to router just in case
    Nov 2008
    Copied the firmware from the working box and it has been stable for well over an hour now.
    Looks like success. Cheers
