Results 1 to 3 of 3
    Default Openbox X3 stuck on L040
    Mate bought himself an X3 box from flea about 2 weeks ago and now it is stuck on L040. Every time he reboots it will say load and then go to L040 and stay there. Any ideas anyone?
    DK Veteran nibblitz's Avatar
    See if it does it without the satellite feed connected, if it boots up ok without dish connected then it could be a problem with the feed cable/plugs/LNB, if its still the same then its probably gonna need a reflash of firmware..
    Hi.. The mate has tried it in 2 seperate houses so guessing the cables are fine. Is it easy to reflash?
